Tob rattle
zach44102
BIG TURBO
Georgia
So over the past couple days I have noticed my 10k mile Southbend stage 2 clutch and stock TOB is rattling pretty loud, enough for me to notice it. I have never noticed untill last week. Now I know this is a common problem on these cars but is that a warning sign that its going to go here soon? How long do you think this clutch/tob has left? When I did my motor swap the pressure plate fingers looked great! and the disc still looked new. Any thoughts?
jayro
Auburn, In
I know thw stock TOB can cause excessive wear on the fingers of your pressure plate. That is why it is always recommended that you use Josh's ceramic TOB. It is pretty common for the TOB to make some noise, but if it is increasing it could be a sign that you may want to atleast get in there to replace the tob and take a look at the clutch.
91PDXmocha
Portland , Oregon
Ive heard shos tob chatter for years without failing and I had one that started to chatter , replaced the clutch a few weeks later and the fingers were nearly trashed . I would check the fork bushings . Grab the top of the clutch fork and try and wiggle it around , see how loose it is .
zach44102
BIG TURBO
Georgia
I have brand new fork bushings. I'm just going to drive the thing till it breakes. I might post a video of the noise.
zach44102
BIG TURBO
Georgia
Yes I got the shosource ones and I had alot of trouble installing them. They were too tight of a fit. Once installed it was so tight that I had to put a big spring on the clutch cable just to disengage the clutch. After 100 miles it broke in.
have you adjusted the clutch cable?
zach44102
BIG TURBO
Georgia
There is no slack in it if that is what you mean. And I do believe that the clutch is disengaging fully.
AREA 91
Area 91
Almost every MTX equipped SHO has TOB rattle. It's pretty normal.
trainguy1989
SHOtarted
Wichita, Ks
Yea I had problems with the Sho Source ones too. Very tight fit and bound up the shift fork. Found some new old stock(OEM) bushings and never had a problem.
zach44102
BIG TURBO
Georgia
The shosource ones work and Wear great. If they only installed easier they would be perfect. Buy after they are broke in they were fine. My old bushing was toast! Anyway thanks for the responses. I knew it was pretty typical of a Sho, did not know how long people drove on one rattling though.
shobroooo
