Tweecer help please.
jmpSHO2nd
Massachusetts
I am new to the tweecer and I am lerarning how to use it little by little. My issue at the moment is when I load the 80mm Lincoln MAF the car runs like crap and hesitates until 3k or so. Right now the 80mm MAF is in there but the car is programmed for the stock MAF and it runs great but as soon as I try loading the 80mm MAF it runs like crap. I know it's an 80mm MAF becaause I thought it was bad so I bought a new one and both MAFs are the same.
http://doxinh.com/danh-muc/do-lot-nam/quan-lot-nam/ Dam ngu sieu mong Do lot doc ao lot doc Do so sinh khac Cho thue trang phuc da hoi Quan lot nam
Sho Amo
SmkTyresntDrugs
Olney, Md
There is a difference between the mark8 maf and the continental maf. Also, lean the entire maf curve out 17%. Do you have a wideband?
jmpSHO2nd
Massachusetts
I bought an 80mm Mark 8 MAF off a forum member last year and at that time I had an LPM that SHO Source programmed for my 80mm MAF but now with the tweecer when I try to use the pre loaded 80mm Lincoln MAF it runs like crap.
I also bought a new MAF for a Lincoln Mark 8 and they are the same so I know it's a Mark 8 MAF.
Quan xi nam Dam ngu sexy Do lot cao cap ao lot cao cap http://doxinh.vn/danh-muc/do-so-sinh-cho-be/bao-chan-bao-tay/ Cho thue trang phuc http://doxinh.com.vn/danh-muc/do-lot-nam/ao-lot-nam/
No, I don't have a wideband yet.
yamahaSHO
E85 whore
Arkansas
Are you loading it with your own files? If not which EXACT 80mm MAF are you loading?
jmpSHO2nd
Massachusetts
I bought the tweecer used from another forum member and it came loaded with a bunch of MAF sensor files and one of them says 80mm lincoln mark 8.
Quan sip nam Vay ngu goi cam Bao chan bao tay gia re http://roses.vn/studio/chup-anh-studio/chup-anh-thoi-trang/ ao lot nam goi cam http://trangbanbuon.com/danh-muc/thoi-trang-cong-so/chan-vay-cong-so/ http://trangbanbuon.vn/danh-muc/thoi-trang-cong-so/chan-vay-cong-so/
yamahaSHO
E85 whore
Arkansas
What does the curve look like? The TwEECer comes with all these when you download it from the site.
jmpSHO2nd
Massachusetts
http://doxinh.com/danh-muc/thuong-hieu-do-lot/hang-rbi/ http://doxinh.com/danh-muc/thuong-hieu-do-lot/hang-rbi/ao-nguc-rbi/ Quan chip rbi http://doxinh.com/danh-muc/thuong-hieu-do-lot/hang-rbi/quan-lot-rbi/ http://doxinh.com/danh-muc/thuong-hieu-do-lot/hang-narsis/
yamahaSHO
E85 whore
Arkansas
You're loading the wrong MAF. That looks like it's going up to 1,550 kg/hr? That's Lightning 80mm territory.
That's what your curve should look like.
26748934041 large
Don't blindly richen/lean a curve out. Load the proper factory curve and work with the injectors if needed.
yamahaSHO
E85 whore
Arkansas
Me too:
26748934042 large
Also, it might be easier to use "print screen" or "alt" + "print screen" over taking a picture with your camera.
jmpSHO2nd
Massachusetts
yamahaSHO
E85 whore
Arkansas
Did someone play with the files? Or did you download it from TwEECer's website?
jmpSHO2nd
Massachusetts
I loaded it from the tweecer site a few weeks ago. I am so ****** because for the past few weeks I thought there was something wrong with the car and I replaced a lot of parts in the process and I never once suspected the tweecer.
http://doxinh.com/danh-muc/thuong-hieu-do-lot/hang-vera/quan-lot-vera/ Do lot winny ha noi ao nguc winny Quan lot nu winny Do lot rbi thoi trang cho be *** do dung cho me
Sho Amo
SmkTyresntDrugs
Olney, Md
For some reason Adam had posted for all the atx cars to lean out their 80mm maf curve 17%. I did some tuning on Scott's car saturday night and confirmed this to be correct. Without the maf leaned out his wideband was maxed out rich at 10.0, then leaned it out and was into the lower 12 range.
yamahaSHO
E85 whore
Arkansas
I'm not sure why they would be different for ATX given the file is the same, but that's what mine loaded at.
whiteguy3
Scott MacIntire
Silver Spring, MD
Idk know why exactly either, but originally Axianator said to do that. I think it has to do with the way the D4U1 binary reads it.
yamahaSHO
E85 whore
Arkansas
That's what I was thinking... Odd though.
I've never messed with an ATX when it comes to tuning.
