Tweecer help please.
whiteguy3
Scott MacIntire
Silver Spring, MD
yeah, it's a bit different. Load based, 2 spark tables (which you can just minimize to one after a process of taking the higher of each value in each box between the borderline and base spark table.) The trans tuning is actually pretty straight forward.
whiteguy3
Scott MacIntire
Silver Spring, MD
BTW I'm loading the 80mm MAF from the Shonut website and I believe it is wrong. The .maf file that comes with the Tweecer software I believe is correct. The one from the Shonut website is clearly different than the one's pictures above. Everyone should be using the one from the Tweecer MAF directory. Someone else should try it out and check back.
Instead of gradually sloping it steeps fast and then tops out above halfway through the curve versus the one in the Tweecer MAF directory looks like the one pictured above.
yamahaSHO
E85 whore
Arkansas
I've got more than 2 spark tables available on the MTX.
