Copper Nickel Brake Lines
operdot
USA
I bought this car(1994 White SHO) for the body because I have a 1993 3.2 mtx that started to rust and was in an accident badly. The 93 has been looked after mechanically but the body is gone. So I decided to keep the White 94 but swap all the parts over. The 94' drove to my house but broke a brake line shortly from moving it around my property.
After doing some research I found that a lot of high end cars and military vehicles use copper nickle brake lines because it withstands corrosion better. I bought some line, bent it into shape and flared the ends.
Brakeline1
Brakeline2
Brakeline3
Brakeline4
Brakeline5
Brakeline6
Westerly, RI
Nice work! I Googled the line, looks like Advance Auto can order it in, or it's available online in a 25' coil. The SHO is fine, never sees winter roads, but the truck is going to need lines before this winter. At $50 for a coil, I think I'll give it a try.
How was the material to work with, in terms of bending and flaring?
operdot
USA
Its pretty easy I did most of it with my hands wearing welding gloves, however some of the tighter bends I used pliers. I kept the old rusty lines as straight at possible to use as templates. Afterwards I roughed up the surface and painted it with por15. Flaring was a breeze too.
LOUDSHO92
Rancho Cucamonga, CA
Monel!
I would just make sure it doesn't make contact with steel or you may have galvanic corrosion.
SHONut has been making Stainless lines as well.
operdot
USA
I think you have a valid point, however por15 coating should help protect the lines from contacting any steel.
When I was installing the lines I took as much care as possible to place the lines so that they don't rub on each other. But I completely forgot about them rubbing on the steel body, I will keep an eye on them to make sure no corrosion is happening.
LOUDSHO92
That should work. Good job on the install.
TimboSHO
Intermediate
Wyoming, MI
This stuff it easier to bend and flare than standard steel line as well. Looks nice!
mrecoolgar
SHO NUP
Hershey-PA
You can use those round foam insulators.
They have a hole in the middle for the line and a large enough diameter to keep them away from things.
crystizel
