atx owners
sho pleaser
nashua
my buddy has an atx that he wants to replace the tranny with another one whats the best way of doing this with no lift
SHOYAY
WNY
Definitely not the best or easiest way without a lift, but you can use jack stands and well supported concrete blocks if you must.
sho pleaser
nashua
does the sub frame need to come down cause i have no idea how the bolts are ive done mine no prob but this kid doesnt have the funds for the kit
SHOtimer
#2910
Santa Clarita, Ca
I R&R's my 3.2/atx combo out the top twice. If I need to do it again, i'll probably go that way again.
Doug
SHOYAY
WNY
The subframe does not have to come down. Like shotimer, some prefer to take out the top and some out the bottom, subframe and all. I find it easier out the bottom.
SHOtimer
#2910
Santa Clarita, Ca
how long did it take the first time
The first time, I took my time taking things apart, bagging them, labeling them, and doing a lot of extra work....so it was several weeks.
The second time, I had the motor/tranny out of the car in a day (12 hour day) and reinstalled it the next day. I was working by myself.
Doug
VortecGT
Wisconsin
Go out the bottom if your doing just a trans swap! If you go out the top you have to remove the motor as well. Why disconnect all the motor associated things if you don't have to. The way I do it is -disconnect front suspension from subframe, remove y-pipe, take out all the trans bolts, disconnect everything on trans, support engine (with a hoist or I just use a long bar to hold it up. Remove 4 main subframe bolts, 2 engine mount bolts, and 2 steering rack bolts. lower subframe and remove trans. Ive only done it twice and the second time it took me maybe 6 hours to have the trans out.
sho pleaser
nashua
out the bottom is the way i wana go im gona see if my buddy will let me use his lift and pray the subframe bolts dont brake i need to get this done in a day thanx for the info
