Just got this broadcast message last week. I am trying to find out if this filter is ok for our car but Im sure Fords response will be to stay with the FL500S. Ford wont recommend changing something unless they test it on a specific application. This filter will also require .2 qt more oil over just 6qts with the FL500S
This is for the F150 Ecoboost and they run over $20
Here is the message
To:All Ford and Lincoln Dealers
Subject:EFC00063DC New Part Number FL2055, 2011 F-150 3.5L Ecoboost Oil Filter
INTRODUCING THE FL2055
Motorcraft is pleased to announce the availability of the FL2055. This all new oil filter is the service filter for the 2011 model year F-150, 3.5L Ecoboost engine.
All 2011 F-150 trucks equipped with a 3.5L Ecoboost engine were produced with a small diameter (77mm/3 inch) oil filter. The service replacement oil filter, the FL2055, is a larger diameter (94mm/3.75inch) filter. The FL2055 has significantly higher filtration efficiency and capacity than most other oil filters and is designed for added engine protection and long life. For proper engine maintenance, a FL2055 oil filter or an equivalent filter meeting Ford material and design specifications must be used.
If a replacement oil filter is installed that does not meet Ford specifications, engine damage may occur which may not be eligible for warranty coverage. The oil capacity for the 3.5L V6 Ecoboost engine with the FL2055 oil filter is 6.2 quarts (5.9L).
(The smaller filter installed on the early F150 Ecoboost is a FL500S)
Here is the message
