New oil filter info
cheech
Pa
Just got this broadcast message last week. I am trying to find out if this filter is ok for our car but Im sure Fords response will be to stay with the FL500S. Ford wont recommend changing something unless they test it on a specific application. This filter will also require .2 qt more oil over just 6qts with the FL500S
This is for the F150 Ecoboost and they run over $20 :eek:
Here is the message
To:All Ford and Lincoln Dealers
Subject:EFC00063DC New Part Number FL2055, 2011 F-150 3.5L Ecoboost Oil Filter
INTRODUCING THE FL2055
Motorcraft is pleased to announce the availability of the FL2055. This all new oil filter is the service filter for the 2011 model year F-150, 3.5L Ecoboost engine.
All 2011 F-150 trucks equipped with a 3.5L Ecoboost engine were produced with a small diameter (77mm/3 inch) oil filter. The service replacement oil filter, the FL2055, is a larger diameter (94mm/3.75inch) filter. The FL2055 has significantly higher filtration efficiency and capacity than most other oil filters and is designed for added engine protection and long life. For proper engine maintenance, a FL2055 oil filter or an equivalent filter meeting Ford material and design specifications must be used.
If a replacement oil filter is installed that does not meet Ford specifications, engine damage may occur which may not be eligible for warranty coverage. The oil capacity for the 3.5L V6 Ecoboost engine with the FL2055 oil filter is 6.2 quarts (5.9L).
(The smaller filter installed on the early F150 Ecoboost is a FL500S)
Crash712us
Chasing my tail
MI
would using the larger filter require a change to the oil filter adapter ******? Or is this what ford is recommending used instead of the FL500S on F150's
Any how I was always told with oil filter if you could fit a larger or longer filter the better. More oil the better.
cheech
Pa
Ford is telling us to remove the FL500S on the F150 and replace it with the new filter. It is a direct replacement.
Most of the changes 5w20 to 5w30 and the new oil filter are because in 2011 Ford went to an active oil life monitoring system. This system can extend you oil change intervals up to 10000 miles. Im sure the testing they have done caused Ford to make these changes for the 2011's and not include the 2010 because of the 5000/7500 mile intervals.
NebraskaSHO
Harumph!
Omaha
I ran an FL-1A on my 99 SHO (bigger than stock) for about 3 years. As someone else mentioned, if you can get a bigger filter on it, it's usually for the better.
Was nice buying two or three at a time for both the 99 and the Ranger.
shaker281
USA
Good info. But, it sounds like it would still be OK to use 5w30 for better viscosity (2010) in the summer and the new filter for better filtration and still change your oil at recommended intervals.
Any reason that would not work?
cheech
Pa
I agree with you. I am running full syn oil 5w30 im mine and probably going to switch to the updated filter.
cheech
Pa
Cheech,
Would this filter be beneficial to use on the SHO?
Mike I can't see any problems using it but I would be.worried if you had engine problems and the dealer blamed the filter. Ford is only using this on the F150 and still calls for the fl500 on the SHO
First-SHO
Michigan
Thank you sir!
wchain
Ecoboost
USA
Oreilly Auto Parts carries these filters. $7.49 all day long.
cheech
Pa
UPDATE I ordered the filter in today. The filter is huge. Im not sure this is going to fit without clearance problems. I will update when I try to install it.
2011 04 28 15 56 35 420
2011 04 28 15 56 52 529
Showgun
Canuck SHO
Cambridge, Ontario
Yikes -- that's the FL-1A size and makes the 500S look like a toy.
Hope it fits without clearance issues. I'd much rather use that one than the little one.
Thanks for checking for us.
Crash712us
Chasing my tail
MI
Holy Cow! is there room under there for this? I haven't changed my oil myself on this car as of yet.
mjhpadi
Pennsylvania
Wow, I hope it fits without problems...the extra oil capacity is also a plus. I like the idea of 6.5 quarts of oil in the engine.
nynd
Ontario
Why change the filter? Stick with whats recommended for your vehicle. Last thing you need is an additional dealer headache that you used the wrong filter.
