oxygene sensor O2 what brand
moobypets
mooby
quebec
what brand do you guy use and trust
since a couple off people told me i was running lean again im thinking that it the onlything i may have a prb since i never changed them
moobypets
mooby
quebec
but bosh are 28.70 and ford are 30.70
and ive read that it better to get a dy-606 cuz they read faster thus giving the computer a more rappid responce
can anybody help me out on this lol
SHOtimer
#2910
Santa Clarita, Ca
The Ford or Bosch will be fine either way. I have always ran Bosch...in my Ford's, just because they work well and never had a problem with them.
Their isn't really a right or wrong answer here, it's your car, your preference.
Either way it will be fine. Are your intake manifold couplers original? You may be getting a vacuum leak through their causing your lean condition.
Doug
firebat45
Edmonton
no i just got my plug out and the color suggest lean
Bougie
All those plugs tell you is what the engine was running right before it was shut off. You let it idle for a few seconds before shutting it off? Then you're lean at idle (which is expected).
If you actually want to test the engine, you need to rev it to the desired range, then shut it off and coast to a stop, then look at the plugs right away. Not the most convenient way of tuning.
itwonder
VA
Really? :braincramp:
moobypets
mooby
quebec
so replaced the 2 oxygen sensor with for since their cheaper then bosh lol and wow whata adifference
as for the leak my rubber are old but still not in bad shape
moobypets
mooby
quebec
yeah i know all that i just decided to got with the best ford lol dy606 cheaper then the best quality bosh and yet im sure the dy606 his the best for our car if not ill replace them in some 120 000 mile
shobroooo
