FSB with Quaife
jon93
Philadelphia Region
What do you guys run and what do you recommend? I have a 26mm in the rear currently.
Combinations I've Seen:
24mm front ~ 26mm rear
22mm front ~ 26mm rear
20.6mm front ~ 26mm rear
I was thinking a 22mm for the front..
Ishodu
IMO you are able to control the under steer in the front with the gas pedal when your running the Quaife and do not require the large bar to help keep things flat like you do with the open diff. I run the 20.6 for now and am thinking about unhooking that for a bit to see what happens.
94shodriver
PNW
Depends on your use of course. See my sig for my set up. For street/track use, I think 22/26 is a good place to start. 24/26 induces way too much push. 22/26 is a tad loose until the rear tires warm up. For autocross or more dedicated track use, I'm inclined to experiment with even less front bar (but I wouldn't let my significant other drive it aggressively on the street ;) ) If you have konis you can adjust the rebound setting to change the transition feel a little bit.
