exhaust tips
93SHOPlester
Detroit, Michigan
i just bout a 93 gen 2 but the exhaust tips that are on the car are aftermarket and i like them but unfortunately they are pretty "used" looking. is there any simple way to clean them. i really dont want to cut them off. already have brand new cat-less with turbo mufflers
93SHOPlester
Detroit, Michigan
on rack
getting final pully done today so i'll have a pic or two of the tips later on
SHOGUN88
1994 MTX
Langley, BC Canada
It depends what the are... if stainless like frosho said or if they are chrome, clean them then use a metal polish on them.
frosho
WOLFMAN
Tyngsboro, MA
If you don't know, I wouldn't get too enthusiastic with the scotch-brite pads. They will remove chrome if you're not careful.
Do they have a "grained" finish, or are they more mirror-like?
93SHOPlester
Detroit, Michigan
ya know they are so *ahem* "used" its hard to tell but at one point it lookes like they were a smooth mirror type finish so i assume they are chrome
93SHOPlester
Detroit, Michigan
as soon as i get the car back. most likely tomorrow afternoon i'll post pics of the exhaust i had some trouble locating a bearing and mounting hardware for my drive belt tensioner that snapped but luckily i got a tip from someone on the website so it should be wrapped up tomorrow
frosho
WOLFMAN
Tyngsboro, MA
Stainless can be polished to a mirror finish, too... but if they look that bad, the scotch-brite pads probably can't hurt too much, even if it is chrome.
93SHOPlester
Detroit, Michigan
so if it is chrome... after i get some off with a scotch brite pad i'm gonna be a little jumpy on tryin to get ALL of it off because i dont want to ruin the finish. and suggestions for that?
frosho
WOLFMAN
Tyngsboro, MA
You could try some chrome wheel cleaner. I know I've used wheel cleaner on my stainless tips to remove some of the soot. You can also use a lighter duty scuff pad with the cleaner. Most grocery stores have "delicate" or light duty pad that is a lot softer than the scotch-brite. They might only come in a combination pad/sponge, but that's not a bad thing.
93SHOPlester
Detroit, Michigan
got the car back tonight. i'll have some b4 pics posted tomorrow then gimme a day or two with work and such before i actually try and clean em then i'll post some afters
93SHOPlester
Detroit, Michigan
well here are the before. i changed my mind i believe they're stainless. excuse the dirt, drove in the snow last night and this morning
Use crumpled up aluminum foil. Won't matter if it's stainless or chrome. It'll be a lot cleaner without scratches.
Oh...now that I see your picture...you could use a hammer and it wouldn't make them worse.
itwonder
VA
They look rusty in the shots. The quick and dirty route would be to sand and paint them flat black with high temp spray paint. If you can get them off of the mufflers, you could probably have them re-chromed, if the base metal has enough thickness remaining.
93SHOPlester
Detroit, Michigan
looking at them close up it appears to have no rust. just a bit of dirt in the pic that appears to be rust. i was thinking about the exhaust paint option but i'm still going to try and clean them first. tomorrow afternoon. as far as having chromed. id need to cut em off and i dont have that sort of experience to weld em back on. AND other things i could spend the money on rather than having someone do it hahah
