1995 White/Mocha MTX - $850
CademiaX
What's an SHO?
Utah
Well, I am very sad to see it go, but I have to much going on in life right now to put money into the money pit. Great car, no major problems, all issues are minor, nothing mechanically wrong with the car. Runs and drives great!
The Basics:
Price lowered to $850, serious buyers PM me for pictures
$1500 - You arrange shipping/pickup
If you are wanting me to drive it to you, I need to be able to do it over the weekend, there and back driving.
~180K Miles (just under)
Receipts dating back for about 12yrs
Located in Salt Lake City, Utah since 2004, originally from Florida
The Good:
Heater blows hot
A/C blows ice cold
ShoSource Catback
ShoSource Silicone Radiator/Heater hoses
Lowered with Eibach Springs
Cobra Wheels
Magnaflow Y pipe (not installed, bought used from ManySHOs, has about 15k on it)
Maintenance:
Top 60K(mostly just gaskets, resealed plug wells correctly) (~10000 miles ago)
Front 60K (~2000 miles ago)
Rod Bearings (~5000 Miles ago)
Rear Sway Bar EndLinks (~3000 miles ago)
Front Sway Bar EndLinks (not installed, metal)
Monroe Struts (~3000 miles ago)
Monroe Strut Mounts (~3000 miles ago)
Monroe Strut Bellows (~3000 miles ago)
Timken Front Wheel Hubs (~500 miles ago)
Timken Front Wheel Bearings (~500 miles ago)
Brake Pads (~500 miles ago)
Brake Rotors (~500 miles ago)
Rear Calipers (~500 miles ago)
Antenna shaft (not installed)
The Bad:
Drivers seat has a tear, passenger seat is in good condition, rear seat has a few punctures.
Not really bad, shifting is smooth as butter, 2nd seems a bit sticky coming out.
Mass Air Flow Sensor (cleaned again, probably time to change it)
Front tires have 5/32 (threw on some used tires, they were 1/32)
Air Bag Error Code 42
Clock doesn't work
Door seals need to be replaced
Front ABS Sensors are shot
Some ******* keyed the hood, driver side fender, driver side quarter panel - no rust, shop told me it could be buffed out.
Passenger side mirror was bust off when I bought the car, replaced it, sheet metal it bolts into is bent up, mirror sits funny, shop quoted me $80 to fix it.
Passenger side e-brake cable is frozen and disconnected
Sub is cracked, disconnected
Antenna shaft if busted off
Blend door actuator is shot
Headliner is falling apart
Passenger side vent is busted
Moonroof control panel is gone
Headlights are yellowing
Rear passenger side window switch is broken out of the part that holds it in place
After the front 60K there is a slight whining at idle
Fuel pump has had a slight whine for the past two winters, only happens when its cold
washer fluid tank is leaking (failed on safety for it, lol)
Well, that's about it, I am sure someone could patch up all the small stuff and make her look amazing again, I just don't have the time any more.
I won't be parting her out, I don't have stock parts to put back on. Minus the stuff that isn't installed, but I would rather keep that stuff with the car as well.
Update 12/11/2010:
Just a couple of updates on the car...
The drivers side control panel plastic broke off last time I closed the door, it was laying on floor. The wife knocked off some plastic on the rear drivers side on the car, plastic that goes around the little window getting the car seat out. Looks like it broke some tabs on its way off. I have seen both parts for sale for 10-15 on the forum, not a big deal I guess.
CademiaX
What's an SHO?
Utah
Ok, I was asking $1500, I am dropping the price to $850 until the end of the year. I need it gone. (ok the wife wants it gone :cry:)
Feel free to call or text me, I reply to text faster; (801) 432-0875
Serious buyers, PM or text me for pictures.
JRA2000TL
The Complainer
Daphne, AL
Agreed on selling quicker with pics, but bump anyway for a super cheap car with lots of minor, easy to fix things. What...nobody got Christmas $ to blow on toys? :evilgrin:
VortecGT
Wisconsin
Well if this car is around after tax returns I'm interested! Do you think it would make it to WI? Pics PLEASE! Also maybe a down payment to hold the car if you are willing! PM me please! Also I'm a broke college student with lots of extra SHO parts sitting around if that would affect the price at all.
tinkerkathleen
