Crank q
I can't find it right now, but I'm curious; why do you want to know? I have a shop manual in the garage, so I'll try to remember to find it while I'm out there this morning.
51.976-52.000mm
2.0463-2.0472"
quake
rochelle il
I had a rod bearing go out,Funny just the one on num 1 cyd Going to replace them all but num 1 looks a tad bit funny.I move one bearing there to see and it still had just a little play.I have a 3.0 motor wit good crank didt what to swap it to my 3.2 lot of work.The crank not ruff but it dont have the shine like the rest.By the way the bearing was thin as paper when it came out,beside small bits was missing
jayro
Auburn, In
What do you mean by "Go out"? If your engine spun a bearing, usually you cant just replace the bearings. It usually causes some damage to the crank, rod or both. This requires some machine work to fix. Unfortunatly, you cant just turn the crank down due to it being surface hardedned. Turning it would remove this and can cause the crank to fail. Since you are saying that it did effect the crank in some way, I would be leary of just replacing the bearings.
quake
rochelle il
No im talking about when i took of the cap the bearing was paper thin.I have a 3.0 crank will it work in 3.2 or iz it turn driff.
jayro
Auburn, In
The 3.0 crank and the 3.2 crank are the same. When swapping parts in the rotating assembly you should have things balanced though. Also, did you check the bearing clearances with the new bearings? Were they in specs?
bubba
ATX Connoisseur
Fort Wayne, Indiana
Hey man, if I read you right, you just don't replace the bad one. I'd replace all of them. I just want to make that clear.
Toolman
Boost it!
Grand Lake, Oklahoma, USA
It is possible to have bearing be as thin as paper and not spin. I assume you checked on it though because you heard a jackhammer coming from your engine bay. If so, your crank is likely toast.
quake
rochelle il
Why crank q
Not to b funny but why should my spare crank out of my 3.0 be turned.Yes planning on putting it in my 3.2.The crank iz fine no marks still exc shine.every thing iz in spec.
yamahaSHO
E85 whore
Arkansas
If it's a good crank, it does not need turned. You will want to balance it with the new mix of parts (yes, you'll need a new connecting rod) and possibly micropolish it.
BTW, "iz" IS not a word.
boat
Likes blue ones
Tallahassee, FL
No, don't turn the spare crank or the damaged one for that matter, or what Jayro said could or would happen. Throw that damaged crank in the trash.
Unfortunately, you cant just turn the crank down due to it being surface hardened. Turning it would remove this and can cause the crank to fail.
Bad one what? Rods? Or bearings? Rods no, just the one that had the paper thin bearing in it. All rod bearings, yes, and the crank
This.
You need a new crank and must replace the rod that had the spun bearing. You can use a 3.2L crank, make sure you iz going to balance.
quake
rochelle il
Btw iz ,just like cuz is a word lol!
quake
rochelle il
Dam you guys are funny as ****,Tru shonuts details details dont miss anything. (iz),Why so funny.Why balance it if useing connecting rods out of 3.0.In 3.2.
jonheese
Used-To-Know-It-All
Fogelsville, PA
It's not just using a crank from a different size motor, it's using a crank from a different motor period.
When these were assembled at Ford, they balanced the rotating assembly first. If you change anything in the rotating assembly (that's crank, rods, pistons), even if it was from another 3.2L, you need to balance it again. In your case, you're changing the crank and a rod, so there's a decent chance that it will be a little off-balance when it's all buttoned up. Balancing it makes sure that it's smooth and doesn't shake itself to pieces (may be a little exaggerated, but you get the point).
