Back at it...
Well its been awhile since Ive messed around with this SHO. Ran out of money and the winter hit, i have to work outside so that kinda slows things down...
Installed a brand new DPFE and it still has the same problem.
There is no way I could have installed the cats backwards, they are direct fit and they only bolt on the one way. Both cats are heating up.
I found that the evap purge solenoid is bad, along with the lines that hook to it. Could that cause the glowing cats?
I took my coil pack to autozone and had it tested along with a used one I got, they both tested good. Ive got the maf, tps, and throttle body to swap out. (my idle screw was broken) Waiting on some money to get more parts before putting it all back together. Need to test my fuel injectors yet, and get a new set of plug wires(what kind should I get?, I hear that a lot of them dont fit properly.), throttle body gaskets, and the evap solenoid....
I really want to get this car going, really dont want to give up on it and take it to the scrap yard. =( any ideas or things I should check out then please feel free to reply.
