Butterflies Help
SHOByrds
Virginia
took off my intake to clean and now it seems like the butterflies are opened all the time
i used to be able to hear them after 4k rpm and now its just really loud the whole time still has good power but not the same way.....it seems like i cant go past 5k rpms because it revs sooo much
whats up here?
and is the black canister valve reservoir with two nips supposed to make a hissing noise?
kevinspann
Don't take my advice.
Richmond VA
whats up here?
You forgot to put the vacuum lines back on for the secondaries, or pulled them off by accident.
There should be a vacuum line for them attached to that black canister.
Where in VA are you?
SHOByrds
Virginia
Dinwiddie its south of richmond bout 45 minutes....you?
im pretty sure i hooked all the lines nack up but il check
kevinspann
Richmond VA
Right outside of Richmond, in Chesterfield.
I got one of my SHOs from a friend that used to live in Dinwiddie.
