strider784
Occasionally, when I try to shift out of park, the release button doesn't work. This is on a '93 ATX 3.2 L SHO. Anyone have a similar problem and can someone help.
Yep. it was the brake interlock switch. Thanks for the tip
first, confirm your brake lights aren't working. once you've done that, open your hood, find the long skinny connector that's pretty much straight down from your master cylinder and unplug it. then locate the blown fuse, either underhood or in the cabin and replace it. now rejoice in your working shifter and thank me later.
No, you take that problem to your dealer to have the recall performed before your SHO catches fire.
You don't want that switch disconnected, I can tell you that. When my switch was bad, my brakes would not operate.
If you electrically disconnect the cruise control deactivation switch, all that will happen is your cruise control will stop working.
If you physically pull the switch out of the master cylinder, then yes, your brakes are going to stop working.
http://www.shoforum.com/showthread.php?t=76641
That's a thread I posted way back when that explains the switch (and connector) in greater detail.
Let's start back to the basics.
If the switch starts leaking, which causes the burned fuse, lines, fire, or ******* in a bunch, it has failed. When this switch fails, it would take a ***** to remove the switch and not replace it because even captain obvious would know your brakes would fail after that.
That said, failure of this switch can cause your brakes to fail, also. I experienced the failure, which resulted in a brake pedal to the floor without activating the brake calipers. Disconnecting the switch didn't change the results because the fault is in the switch. A failed switch has the potential at any given time, even when you think the brakes are working, to cause your brakes to not function. Been there, done that, had 3 ATX SHO's that had the recall performed before it even became a recall. Your thread was just relaying information already known years before that by other SHO members...
The moral of my original post is, don't ignore the problem by just disconnecting the switch, but replace the switch or you might end up killing yourself. The fluid will gush out of the connector. Understand now?
Man, you really don't like me, do you?
Now please, lay off the veiled personal attacks, they're getting old.![]()
hawkeye18 said:The point of the thread was so that those not part of the elite-awesome-SHO-gods club might learn about the problems with the switch, and learn that they should replace it ASAP - as my thread told them to do.
hawkeye18 said:The moral of my post here is, the cruise control deactivation switch had nothing to do with the original problem, and while yes - replacement is always a good idea, it wouldn't have solved OP's original issue.
No one is personally attacking you, maybe it's the parania you are suffering from being stationed in Iraq.![]()
Yes, just like my last post was to inform you of the other problem, which causes the brakes to fail. Your post and SuperHO's can mislead others into thinking that disconnecting the switch will solve the problem, which it can but still presents a more serious problem. I explained that problem, and now I'm accused of personally attacking you.![]()
Yes, but it contributes to the post made in this thread about the possibilities of why an ATX will not shift out of park. If someone comes reading this thread with the same problem and the brake pedal switch is not their problem, they will read SuperHo's post, then your post backing up that disconnecting the switch will not cause brake failure, which I pointed out it would. I'm sorry you felt insulted and took this as a personal attack after the fact that I was just trying to help inform other members when I countered your post.
I am finished with this and hope that someone can benefit by my post, realizing the potential hazardous situation that can be brought about by ignoring a failed master cylinder switch.![]()
