Annoying chirping coming from the font wheels...
Cl-Slick
SHOs b4 HOs
Mobile, Alabama
As the title states, my SHO has developed an annoying chirping sound in the front wheels. It only happens when the vehicle is traveling from about 15-45mph and stops when I press the breaks. I would love to know what it is and get it fixed, the sound annoys me and draws attention to the car. Any ideas?
zak
east of Hartford
Does it only do it when you hit a bump or road irregularity or when initiating a turn etc.?
zak
east of Hartford
Is it a regular chirp-chirp-chirp based on tire rotation speed, or does it do it sporadically/here and there.
sho_shane
Campbell, TX
Just driving down the road. If I have time before work I'll try and take a vid of it.
I would guess with the brakes being new that who every put them on did not bleed all the air for the lines. You have a calber that is skiming the rotor. It will make it chirp and when you hit the brakes and it makes full contact the chirping will stop. :)
Cl-Slick
SHOs b4 HOs
Mobile, Alabama
It is based on tire rotation.
Thanks for the tip! I'll look into that!!!
frosho
WOLFMAN
Tyngsboro, MA
The pads should be in constant contact with the rotor.
Did you bed the new pads? If not, do that.
Cl-Slick
SHOs b4 HOs
Mobile, Alabama
What does "bed" the new pads mean? I personally didn't do the brakes on this car so I'm not sure what's all been done. I'm willing to try anything to fix it though.
AREA 91
Area 91
I could also be the brake backing plate making contact with the rotor. Check around the lower ball joint.
deercrusher
never running!
PA
x2 on what area 91 said. Look at the rotor straight on from back to front, or front to back while you slowly turn it and watch for the backing plate (dust shield) rubbing against the rotor. Sometimes they sound like a rubbing noise but other times they can sound like a chirp.
Cl-Slick
SHOs b4 HOs
Mobile, Alabama
Thanks for all of the tips. I'm waiting to take my math test right now so depending on the time I'm finished I'll try and take a look at the car.
crystizel
