Passenger Window Ground Issue
nothingtoseehere
So I decided to dig a bit today into my passenger front window not working. If I jump the switch leads to the door lock grounds, it works. I can do each led and get up and down from both the pass control and the master control. So, obviously, the ground for the switch is bad. I try jumping that ground to a good ground (door lock) and nothing.
Anyone know where this ground actually ends?
Westerly, RI
I'll look in my 92 EVTM tonight and see if I can get you any help. Should be the same as 95, I would imagine...
