extra plug on harness
sho4life
midwest
so i found a plug, its grey squared shape but inside it it is oval with a red stripe on top. what's it for? its not plugged in to anything and my car runs like crap. is this why? i know a guy told me there are two smog plugs that have a fuse type block in them and they will make the car run like crap if unplugged. well i found the two and they are plugged in so im wondering if this mystery plug i have not in use should be plugged also.. help!!!
kevinspann
Don't take my advice.
Richmond VA
What kind of car? ATX or MTX
What year?
Picture of the plug? It sounds like one I found on both of my cars. Not plugged in.
rbruso
unlikely
Tucson, AZ
The simplest way to post pictures is to host them somewhere (such as at shospeed.com) then link them here with the tag.
Full details here: [url]http://www.shoforum.com/faq.php?faq=vb3_reading_posting#faq_vb3_attachments[/url]
jonheese
Used-To-Know-It-All
Fogelsville, PA
How 'bout a rough approximation where you found it? Behind the intake? In front of the alternator? Behind the headlight? Under the oilpan? etc.
So far it sounds exactly like ~30-40 different connectors under the hood.
jonheese
Used-To-Know-It-All
Fogelsville, PA
How many pins? Can you tell what wire colors are coming out of it?
(Or just post a pic :))
jonheese
Used-To-Know-It-All
Fogelsville, PA
I went out and looked under my brake booster on my two '90s, and I didn't see any square/rectangular grey connectors with an oval recess in that area. A handful of black ones there, and a handful of round grey connectors there, but nothing that matched the description.
May be a Gen2-only connector?
A pin count and/or wire color report and/or picture would help immensely.
sho4life
midwest
im thinking a gen 2 connector too because i found an extra harness and it didnt have it. ill be back on here in twenty mins to describe it more in detail
sho4life
midwest
three wire, brown/green brown/white taniish /red . also it isnt not on the main harness but on a harness that connects the oil sender, temp light, o2 sensor, and a few others. when i mentioned oval before i said oval inside a rectangular plug. and no there are not a gazillion rectangular plugs under the brake booster.
hawkeye18
Sorta cares
Norfolk, VA
well I can't find crap on it, but all I have is the 93 EVTM with me and I know there were some wiring changes between 92 and 93 so...
all I've been able to find is that Brown / white is a voltage reference to at least the BARO sensor and the TPS, that Brown / green is EGR (which you don't have), and Tan / red goes to the EEC test port. So you might want to probe the BR/WH wire and see if you're getting 5V... and if you are, that means something somewhere isn't.
sho4life
midwest
ok, it must be a 92 only and im taking a picture and posting it very damn soon. someone will tell me what this is hopefully
DavesNOThereMAN
NJ
Its a factory test port or some crap. Every SHO car I came across has the same thing just dangling. I also have had 93 and 94 MTX shos and they have the same plug dangling around not connecting to anything. There are a few of them in the car. If you do a search someone explained it already.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
I know the one your talkin about.... I have the same one hanging too... let me dig thru my pics and let me know if its it... :)
Edit: Is it this one?
Connector
Mine's been hanging like that since 92... no worries man..
sho4life
midwest
ok, thats it.. so since its useless on to the next possible problem... man this car is a pain in the ass to diagnois
