V8 SHO parts
I'm parting out my '97 and the '96. The '96 has no drivetrain. The '97 has no suspension (except GM rear arms).
Seats are all gone.
TCE knuckle braces SOLD
Low mile motor and tranny, about 15k on both. You pick up.
Tons of used parts not on the car.
tardboy21
Woodbridge, NJ
May think of some more parts later, but figured I would check on a few others first.
Engine Wiring Harness (non-99 preferred, but any will work)
Rear intake and exhaust cam
set of valve cover gaskets
Intake plenum
Thanks,
Matt
rear strut/mount/springs?
I have one new rear strut. $100 SOLD
One new front strut. $100 SOLD
Two used front struts, ~10k, miles. $75 each. SOLD
Two OEM MAD front springs.
Intake plenum
Thanks,
Matt
I have a '96, '98 and a '99 engine wire harness. $35 for either. '98 harness SOLD
I do have an old motor that the cams are good in. The engine was left out in the rain (not by me) without cover and I have never opened it up. But it was running prior to the soaking.
I have a Jet Hot coated intake that has been gasket matched, never installed.
Jet hot intake parts 3
Two sets of phenolic spacers.
Anything big is pickup only.
I have a new block with new head gaskets. $650
A used motor with welded cams, ~65k miles.
The motor and tranny with SCT flasher from the '97. Both have around 15k miles. Dynoed 208 hp to the wheels.
All items are +shipping. Usually need to have an address and the items packaged before I can get accurate shipping cost.
tardboy21
Woodbridge, NJ
Definitely interested in the 98 harness. If your willing to separate the cams from that motor, let me know. As long as the bearing surfaces aren't rusted it'll be alright.
Also, couple questions about that intake. Do you have the gaskets for it or would new ones be needed? Also, has the LIM been altered to accept larger injectors, or is it the stock injector size?
I appreciate your response, and PM me a price for the cams and manifold setup. I like it all, but gotta see how much I can pony up with some of my other projects ATM.
The LIM has been gutted but when Jet Hot hot tanked it some of the plugs were eroded do that would have to be redone. No big deal. The FI ports have not been altered.
I do have new intake gaskets.
I would be able to take the cams out but it would be later this summer.
zak
east of Hartford
Have any specs on that flex pipe? Diameter (OD/ID, OD/ID of actual flex section), ****** bolt center to center, etc.
That flex pipe is currently on the car. The flanges are the OEM ones from the third cat, 2.5". It is a direct replacement for the third cat. IIRC
SuperHO
Mental Patient
St. Joe, MI
got any used tuners laying around collecting dust? and how much ya lookin to get for the lower mileage engine and trans?
Here's some wheels and tires I have
These have Kumho Victor Racers on them. One no good, three good for a couple track days. 16x7.5.
Asa wheels
Here's some Enkeis with Kumho MX. Both only a year old and tires are 1/2 good tread. SOLD
Enkei wheels SOLD
These are some brand new Bridgestone something or other. Z rated summer tires. SOLD
Tires SOLD
Old '99 SHO rims with Nitto EP 450s good for another year. Used them for my winter tires. Rims need repainted as clearcoat is worn on the sharp edges.
99 wheels
Here are some new Pacer 16 x 7 wheels never installed.
Pacer wheels
Not for me, they are from the TCCA thread. Maybe you need to be a member?
1-24 mm front sway bar SOLD
1-22 mm front sway bar
1-26 mm rear bar SOLD
1-19mm rear sway bar
