93whiteatx
NEED SHO BADLY
OK guys I traded my explorer even over for a 94 Mtx that is pretty clean. Jus needs some minor bugs worked out.
Problem 1.) Car misses when you give it more than normal gas. However after the secondaries open, and I give it full throttle it quits "missing", but it feels ball less sometimes. Other times it just chews the tires. Problems more than not are when the car is warmed up. This leads me to believe it is either the DIS box on the pass. side of the intake, or the actual coil pack. Let me know what you think? Could be as simple as a set of plugs and wires.
Problem 2.) The A/C worked when I got it. But there was a leak on the high pressure side (I believe. It's the front fitting) so I used a can of the R134A w/ stop leak. It stopped the leak, but now my compressor won't kick on by itself. I took a broom stick and barely touched it and it kicked on and WOULDN'T kick off. The a/c was very cold, just the compressor won't kick on and off by itself.? Any ideas?
Thanks alot guys!
Thanks alot guys!
