Radar install question
SHOTom
Michigan
Getting ready to run the wire for my Valentine one, has anyone removed the panel on the side at the front window? looks like it has one small speaker there, I have to run the wire up to the top by the inside mirror. Thanks
thebigjimsho
LSA = YUM
Worcester, MA, USA
Are you running it down low on the driver's side? It seems universally acceptedto tap into the dome lights, especially if you run the detector high-center...
SHOTom
Michigan
Yes, driver side for the wire, I am mounting the V1 on the glass just to the left of the mirror. Was not sure about pullng the side panel off with the small stereo speaker in it.
kikkinasphalt
Wrrrrrrrr
Missouri
ran mine along under the headliner and down the pillar and under the dash to the fuse box.
only way to properly run it
classiccars
Ohio
That cover just pulls off. There is one metal clip at the top that can be hard. It may break. Mine did. I used silicone to put the two pieces of the chip back together. It worked fine. The speaker has a connector that can be unplugged once the cover is removed
Retnavy
Delaware
Sorry guys, I know this may be a little late, but, no one was making any post that I felt I needed to reply to. Been off the grip for the past few weeks. Anyway, there is a company that makes pigtails for the V1, It plugs into the plug into the back of the mirror, if you have the autodim mirror. Try Safe-n-Sound1.com. Give about 6-8 inches of room to mount the V-1 on the glass. Up, out of the way, no cable to route......
SHOTom
Michigan
Had my Ford dealer do the wire install last week, already my V1 has saved me!:sun:
JWadle
Colorado
Mirror Power
I'd like to do this but can't find which leads to the mirror to use. I have the auto dim mirror in my 2010 SHO. What color wires do you tap the Safe-n-Sound cord into? Does it power up with accessories or only when engine is started?
Thanks for any advice you can offer.
Retnavy
Delaware
Check your mail.
michakaveli
SC
Anyone have any pix they are willing to post of how they mounted their V1's?
Billm0066
Caliper Covers
USA
Mount it to the left of the rear view mirror. Mine is in a perfect spot. If you put the visor down, the sensor still shows to the right of it so it still picks up rear signals. Tuck the wire in the headliner, down the a pillar, to the fuse box. Piece of cake.
dbulldog
IL
Hi:
I used Blendmount's V1 mounting to the mirror and then ran their 3" power adaptor to the voltage point on the back of the mirror. The way I have it wired is that it's powered on in every state except when going in reverse to remove any distraction when viewing the reverse camera.
www.blendmount.com
IMG 20111006 00129
gipraw
Pro Detailer
Cypress, TX
I mount my passport using a blendmount also. I ran the wire down the a pillar because I like using the remote mute button. I just pulled the a pillar cover out until the first click. I didn't see a need to totally remove the pillar cover.
I ran the cord for the passport, plus my scanguage, which is mounted above the mirror on a blendmount, under the headliner, then down the a pillar. There is a nice place with a lot of room behind the kick panel to stuff the extra cat 5 cable from the scanguage, along with the coupler.
harder99
Delaware
I can get photos if you are still interested. Installed a Passport 9500ci (remote detector with jammers)
harder99
Delaware
Hope the photo link works ... first time uploading photos.
http://www.shospeed.com/gallery/gallery/album.php?album_id=97
album.php
