HID'S in fogs
frosho
WOLFMAN
Tyngsboro, MA
Well if IIRC the stock headlights for GEN I have a design on them to focal the light out as a beam and not scatter it. With HID's. Thou it may. Now the driving light. Yes I do know they are prismatic but, from what I have seen so far they scatter the light wide and narrow and, not all over the place
:huh:
pretty sure you are the one i was having this same argument with almost a year ago when i had my HIDs installed and i used the same 'I never get flashed from traffic' comment.
i also remember you challenging me to go take a picture at night of how much scatter my HIDs threw off at night and when i went to go do that i never even bothered since even with the beams adjusted all the way down it still scattered 20ft up the building i had the car pointed at from 20ft away.
head on in dim light pics dont work, take a pic from behind the car with your headlights pointed at a building from a 40ft distance in the dark if there isnt a definite difference in the amount of light shining below 3ft up the wall and above it. you fail. sorry. i was officially pwn'd back then as well.
Don't think it was me. Both because I don't remember such a conversation and also because asking for a picture about lights does not sound like me......since most cameras have automatic lighting compensators, I know the results would be contaminated...therefore I would not ask.
DDakRT
Mississauga, Ont, Canada
I remember that thread and I was one of a couple members that asked for a pic.
As for a camera automatically compensating for light thus making a "contaminated" picture irrelevant, not true at all.
When you're taking a picture of the light beam against a wall you will be able to see how much light gets scatter above an acceptable height; the camera might automatically adjust the white balance, aperture, ISO, etc. but it will not eliminate light from the image. You'll clearly be able to see the scatter and hotspots; remember you're not looking at the colour or brightness accuracy of the picture, but rather what's in it.
Check out the pics below, I don't care what the camera did or didn't do automatically, it's pretty clear which set of lights will and will not blind other drivers.
Beam
300672075 cd1c169824
Vnuk1
Mr. Mayhem
Preparing for where this thread like many others has already gone!
:argue: :rainshit: :blah: :rant: :lalala: :cuss: :gayroll:
Vnuk1
Mr. Mayhem
Touche...
[YOUTUBE]<object width="640" height="505"><param name="movie" value="http://www.youtube.com/v/p2r-0yhHy3s&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/p2r-0yhHy3s&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="505"></embed></object>[/YOUTUBE]
SeanMc
NoMoSHO
IMG 7234
I actually haven't had any problems. What I have isn't an ebay kit though, it's JD Lighting in proper housings. Been behind a lowered car, and he said they were fine. Even my landlord who is photosensitive said after the initial shot when I turn them on, after a few seconds, they are ok. When on, it looks like natural light, not a blue blinding mess.
shoboy92x
Damascus,Maryland
I have a DDMtuning 55watt 8k hi/lo (cant tell the differance with hi and lo)kit in my stock headlight housings with no problems from other drivers. I also have kc 26 series fog lights with DDMtuning 55watt 8K H3's with clear leans no diffusers. Those are extremely bright, if I forget to turn them off with oncoming traffic they will flash or just go to high beam every time. I m working on getting projectors, baking the headlights and sanding the glass smooth and retro fitting it. No idea how it is doing to turn out. I have not seen anyone try this any Ideas if anyone has with a 92.
shobroooo
