Pics of relocated EATC's?
Mike93
Go Sabres!!!
Buffalo, NY
Hey forum, every search I've ran has brought up old posts with dead links for any pics. I'd like to see some interior shots with the EATC moved to the lower din slot where the radio lives.
Thanks!
Ashley_MTX
North Carolina
Ok so my car's not quite so fancy with blue lights and special seats and whatnot. But I do have a big hole between the gauges where you can see some wiring.
Here you go:
JanuarySHO010
JanuarySHO011
JanuarySHO012
hawkeye18
Sorta cares
Norfolk, VA
It doesn't even come close to snapping in. Much work with a dremel and zip-ties was required to get it to look like that. I'd explain how we did it but we pretty much winged it and "made it look right". You'll have to cut a significant portion of the surround away, and we had to lop part of the EATC off on the sides to get it to fit as well. Best use of a 4.5" disc grinder I've found yet! That thing eats through plastic like buttah!
Ashley_MTX
North Carolina
Well...there you go. That sucks- I'm replacing my EATC with a hard button unit. Maybe it'll be magic and fit just fine.
