Ford engine block heater 4 gen 1/2!
FOMOCOTOSHO
I eat Rice.
Moorhead, MN
Hey Everyone,
I did some checking around to try and find an engine block heater for my '95 ATX and apparently no one makes an aftermarket one I could find (Checked Autozone, O'Reilly, Napa, RockAuto) and the one from Ford has been discontinued. Ford did a search & found some locally in my area if you can believe it. (Fargo, ND) So if anyone is looking for a block heater for their Gen 1 or 2, you can call:
Soby Motors of Walhalla, ND @ (701)549-3711
He has 2 more after I ordered mine today for like $35.
Thanks
hawkeye18
Sorta cares
Norfolk, VA
lol, if there's anywhere that would have engine block heaters, fargo, ND would be about my first place to look.
gmail
Well-Known Member
sunbury pa
i forget the size of the freeze plugs i wanna say 38mm so any block heater fitting a 38 mm do a search to be sure tho.
make sure you get a good one not a cheapo because the cheapo ones sometimes use rubber and the heater part threads in and expands the rubber to make a fit... many cheap ones leak.
FOMOCOTOSHO
I eat Rice.
Moorhead, MN
That's why I posted this... This is the O.E. Ford block heater that has been discontinued.. not some cheap aftermarket one
