no brake lights
badcamelot
Utah
Was told that I have no brake lights by the **** shop who changed my oil and sure enough no brake lights. I do have park/headlight lights in the back and turn signals and flashers work. So bulbs are ok.
Here is what I have checked so far:
All fuses under dash - all ok.
All **** fuses - all ok.
Searched under dash and around brake pedal and all connecting wires, clips and connectors there - all ok.
So Im baffled. Anyone else have any ideas?
Thanks.
ShadetreeSHOguy
Postwhore
Dallas, Ga
there is a brake petal light swich on the upper side of the brake pedal. Have to contort a little bit, but you can look up and see it. It's a 5 dollar part. Change that it'll be good to go!
1993MTXSHO
Its a Taurus...
Jersey
Yeah the BOO (brake one off switch) mine actually just happened to come upplugged, check to make sure it didn't just pop off.
badcamelot
Utah
I looked pretty suspiciously at all those sorts of clips and plugs, so Im pretty sure it isnt unplugged. There are two pieces attached to the brake pedal, im betting its the one that has wires plug into it right? And not the piece that is white plastic and looks as if it goes to some sort of vac device.
badcamelot
Utah
that was it!
Thanks guys, that was indeed the culprit. Only sad point is my part was $8, I guess the state has to make up revenue somewhere without all that beer being sold in Utah!
Cheers
:thankyou:
