TCC electrical Fault code
JVANBUREN
holly, mi
I just finished putting an engine in a 98 SHO and I am getting the TCC electrical fault code. The car was sitting for quite some time but the tranny appears to be a fresh rebuild, with all new seals and it is very clean and the fluid was new but now that the car is running the O/D light flashes and I get this code, so I swapped The TCC solenoid and that is not the problem and the car is still like jerking at a constant 55 or any speed around there when your cruising at the same speed. Thanks for any input!
Mr Anonymous
Tire Wall
St. Louis, MO
Which TCC solenoid did you use?
'98 & '99's require the solenoid with the blue connector. Using a solenoid with the white connector will cause the symptoms and DTC you describe.
