Gen III cam-welded engine, ZF rack, AGSP-32PP, Mustang GT PBRs, MTX (updated 20 Sep)
Storm-Chaser
Shit Louis
Parts added . . . .
In reference to the Gen III ABS Controller Modules:
I have verified through two different dealer-sources, that the Gen III control modules - according to Ford - DO NOT interchange, nor do the part numbers superceed within any of the Ford Parts information systems. If anyone has any information to the contrary, please post back here so I can get a copy of the information.
I don't know what the difference is. Ford lists three separate part numbers and I do see some superceding part numbers, but none that cross between the model years as listed. Those listed for the 1996 start with F6DZ- and superceed to F6DZ- part numbers, the same for the '97 (F7DZ-) and '98/'99 (F8DZ-) modules. I'll ask around, but for now, my impression is that they do not interchange.
While the ABS pump is the same for all four Gen III model-years, the control modules are electronic modules and it may have to do with voltage/resistance feedback values the modules use, provide, or both. It may be with how the ABS module interacts with the ECM/VSS, as there are quite a few ECM modules. I do know that is why transmissions tend not to interchange from one year to the next following the change to OBDII (for many auto manufacturers) - because of changes in the electronic modules and shift solenoids, even though the transmission hard-parts are the same.
I have heard it does not matter. What is noticeably different between the model years?v
Sure. The '97 module, or are you working on something else ?
The modules are unique to the SHOs, and are unique year-to-year as follows:
  • 1996
  • 1997
  • 1998-99
SHODWN
Mother Threasa
Spencer,Ma usa
Parts added . . . .
Not reading all of this im assumeing that your asking is the ABS controller from different years can interchange? YES ALL SHO ABS controllers will interchange between the years.
mustangracer91
"Super Dave"
Enid, Oklahoma
I haven't talked to him in a while about it, but I am looking to have "st. louis SHO" do an engine swap on my cam failed '97 SHO, and I was wondering if you still had that welded cam 3.4L v8 available, and if I bought that engine if it'd be possible to have it dropped off at his house? Also, I'm looking to do the MTX swap on it, and I was wondering if you happened to have a suitable MTX laying around you'd like to part with?
kikkinasphalt
Wrrrrrrrr
Missouri
the welded 3.4 is still there.
if you have James swap your motor everything will get where it needs to go.
lingyuair
