Bad multi-function switch?
jmpSHO
Massachusetts
Will a bad multi-function switch cause my wipers to stay on after I push the washer fluid button. Also when I turn my wipers off they don't go all the way down. When I shut them off they stay at the same spot.
hawkeye18
Sorta cares
Norfolk, VA
Could either be a bad MFS as you indicate, or possibly a bad wiper motor. I'd replace the MFS first, though, as - honestly - I think it's easier to change.
I have a 98 SLO that was exibiting "bad MFS" symptoms.
I replaced it with a good one from a 92 and it works great.
So I would say that "yes, a gen 3 MFS will work in a gen1/2"
Is it an "upgrade"?
Only if you like the way it looks and feels over the old knurled handle.
