radiator "were to get one"
ThatShoGuy
michigan
where is a good place to pick up ether a new or re cored rad from or maybe if someone had one they wanted to let go of?
Thanks!
SHO U UP
SHO Guru
Virginia Beach, VA
Thanks!
Hey,
I picked up one for my friend's '99 from Napa a couple months ago. It was a new one, not a re-cored one. Still doing fine. The lower driver corner had a leak that kept getting worse on her stock one. Hope this helps.
ThatShoGuy
michigan
yea i think my tanks are starting to leak the little foam part along the bottom is always soaked and the drain was just replaced the few months back. coolant light came on figured its time to address the issue before i cause another prob!
SHO U UP
SHO Guru
Virginia Beach, VA
Yeah, the foam being wet is a given. The low coolant light has always been a problem with the degasser tanks. Gunk builds up in there and makes the float stick. Long as you can see fluid in there it's fine. Also best to get the completely clear degasser tank as well. And watch the hoses. I just replaced almost all the ones from the water pump to the heads under the T-body. Rotting from the inside out. Keep your eye on that dash gauge bro! ;)
ThatShoGuy
michigan
I have one new in the box. :)
i wish i could afford new right now i always would like to replace things with NEW. but with me trying to get my other car on the road and this just starting to get worse i need to fix it b4 winter comes.
because dont we all know cars only like to break when its really cold out:nut:
You probably still have a new motor in a crate too don't ya Paul?:nut:
i got one in my sho with about 13k on it =P
Well I have two used radiators.
If the tank is leaking take it out and recrimp it. Easy to do with a vise grips.
ThatShoGuy
michigan
i was thinking about doing that in a vice but didnt think it would work :nut:
the rad it self from what i can see looks good still just the tanks look like they are leaking and always wet were they connect.
