3.2 swap Q's
ckinney89sho
fo SHO
NY
what do i need to do for a 3.2 swap, including parts and accessories. what can i keep on my 3.0? how much gain do i get when comparing the two?
firebat45
Edmonton
Gain? Not much, don't bother doing it if you aren't really into SHOs that much. If you are really into them and want to get as much power as possible, go for it.
You need the 3.2 with no accessories, then unbolt all accessories from the 3.0 and bolt onto the 3.2. You'll need to cut a chunk out of the front head. You can switch to 3.0 cams for more power, or keep the 3.2 ones for low end torque.
ckinney89sho
fo SHO
NY
im kinda confused. i thought the 3.2 swap was taking 3.2 heads and putting them on the 3.0, but thats not what im getting out of this. can somone explain a bit please.
Blackdr16
93 SHO
Washington, Illinois
The 3.2 swap is taking the 3.0 block out of the car, take all accessories off it, get your 3.2 block, use the accessories from the 3.0 on it. If your using the heads that came from the 3.2 youll have more low end torque but not as much power. Also the 3.2 front head has a little different bolt setup for the alternator i believe. (drill and tap one bolt hole if im correct.) If you want to use the cams from the 3.0 for more power, I recommend using the heads off the 3.0 (same exact heads) and youll solve both the alternator bolt problem and have your cams with it.
Cocoa,Florida
what makes it a 3.2L is the increased bore.
you dont have to drill and tap anything,just swap everything over from the 3.0 onto the new 3.2L. cut a chunk off the front head bolt it up and go. as far as engine swaps go its easy.no extra wiring just nuts and bolts.
ckinney89sho
fo SHO
NY
that seems like a lot of work for a few whp. i have the 3.0 and it does just fine, its fast and i already have lots of fun. I'll just S/C it later on. Thanks for the input
AREA 91
Area 91
These engines are very efficient in stock form. Therefore, They are expensive in the "cost to horsepower" ratio.
Small block V8 headers $100 and gains 25 HP.
SHO V6 headers $600 and gaines 8 HP.
These suckers get expensive quick.
SHOhopefull
Boaz,Ala
Why won't the Serpentine swap onto a 3.0? Is the engine bay that much different, or did they just move everything around? Reason I'm asking is the P/S belt is scarce around here, and so far mine has eaten 2...
rick-ng
Rickybobby
Dallas
Why do you guys need someone to tell you how to do everything???
Just buy a 3.2 pull out the 3.0 and compare the two side by side!
Cutting the head is easy I did mine with a grinder
Just check the rod bearing before installing as SHOs are always needing maint.
-Rick
