Hesitation
levit99
showorthysho
chicago, glen ellyn
ive done all the searches but couldnt find anyone with the same effects so here goes... the car hesitates under 3k then runs fine. no CEL. new wires plug, coil, dis, cleaned throttle body, cleaned mass air. what am i missing. its a 92mtx so no egr. weird thing is it doesnt always do this and not just under load. it hesitates and studders when i just rev it in nuetral.
open to suggestions.
thanks
Phoenix
SHOHOLIC
QC , Canada
yeah before and after. and checked that like 10 times to make sure.
If you checked with a chilton manual , no wonders. Here is the correct way:
If not , double check your DIS , maybe swap it with another good one to see what happens.
frosho
WOLFMAN
Tyngsboro, MA
Pull the codes. Even though there's no CEL, there may still be codes stored in the computer.
Have you swapped out the cam sensor at all?
shobote
Naperville, IL
Did it have the same problem before putting all those parts on ? If not, then one of those, or how they were installed is likely the culprit
levit99
showorthysho
chicago, glen ellyn
havent replaced the cam position sensor. that was the next step. all the parts were put on sepretly not at once. been chasing this problem for some time but recently got worse and starting to get really annoying.
92MTX
Towley rules!!
Texas
Just had the same problem..
My MAF was bad, TPS was bad, and 2 of the 3 rear plug wire boots had
Vertical cracks in them.. I had to pull them out, and look at them all the way around, before I spotted the cracks.
I used 2 spare wires, changed the back 3 plugs, and it runs great now.
Your MAF can be bad for a while before it throws a code..
I suggest switching out with a known good one.. :munch:
levit99
showorthysho
chicago, glen ellyn
would it make a difference if i used a coil pack from a 3.2atx car?
as for the DIS is there anyone here in Lexington, KY that wouldnt mind swapping for a min :)
Crank cancer???? explain pls
92MTX
Towley rules!!
Texas
LOL, my ex is in London, KY.. :dribble:
A coil is a coil..
I just swapped engines, so I have a spare of everything.. hehe
Blackdr16
93 SHO
Washington, Illinois
I have a 93 MTX that had the same problem as you described, I replaced the crank position sensor and it fixed the problem.
Has your engine ever been hard to start also when your having this trouble? mine sometimes would crank and crank before it would start and sometimes run just fine
Blackdr16
93 SHO
Do you plan to do the crank sensor yourself or have someone else do it? Its not that easy but you could save yourself some $$ if you do it. Im in the Peoria area if that answers your last question :)
levit99
showorthysho
chicago, glen ellyn
so just got a hold of a known good mass air and known good dis module. put them both on and getting the same problem. just bought a cam position sensor will report tomorrow.
thanks for all the help so far guys!!!
shocar
shocrazy
Bend
you might check the ground wire that connects to the fire wall or strut tower. on the passenger side. There is a chance that the connections is faultly because it is slightly corroded were 2 wires are crimped together. This is a direct ground to the computor and if it is loosing it ground with the vibration of the motor, it may cause this.
levit99
showorthysho
chicago, glen ellyn
so got the new cam position sensor on it and still acting up. i was wondering if there were any common fuel problems. i am leaning twards the fuel concern because of the backfire. it makes a poping noise in the exhaust. could i have a leaky injector?????
