94 MTX; green with 50/50 mocha; 2,000 Updated...AGAIN...MUST SELL!
Shopower400
Atlas
Electric City, NY
This car has 135k on it now, and runs perfect! I bought it back in July 06' with 80k. Most of the mileage has been highway as I frequently traveled from Dover DE to Albany NY, and back. (300 miles each way) I have done my very best to fix, and comb thru any, and all problems, and 'annoiances' that these cars usually develop, like burned out window motors & switches; seat switches; antenna; etc...................... I will list the good as "GOOD" and the bad as "BAD" So here goes.............
GOOD:
-Fully rebuilt tranny w/ LUK racing clutch & 9lb Fidanzza flywheel($2,500)
-HD reinforced motor mounts
- Flowmaster 40's catback exhaust($500)
-Gen 1 front sway bar w/ poly bushings & HD endlinks
-ALSB's
-New 'blinker' assembly
- New CV axles
- New inner & outter tie rods
- New control arms
-Upper 60k complete. (plugs/wires/coil pack; valve cover gaskets; plug well seals; serpintine belts; cam sensor; valve lash check/adjustment.)
- New radiator w/ hoses & thermostat
- Various minor things fixed such as window motors/switches; sunroof switch; antenna; center console; the box that sit under the radio; & probably some stuff I can't remember right now.
- All regular maint. has been done on time like oil changes, fuel filter, clean air filter out, and regulary wash & vaccum her out. (pics should speek for themselves)
BAD:
-Needs driver side strut mount (i'd recommend replacing both though)
-Needs Tires
-Could use rod bearings(not making any unusal noise yet.
-Could use lower 60K (does leak about 1/2 quart every 3000 miles from the rear main seal)
-Cruise Control inop. (This is the ONLY accessory/luxery item that dosn't work)
This is just about it. If I remember something i missed, whether it be good or bad, i'll be sure to add it. The reason(S) why i'm selling.......
-Can't afford car ins. on 3 cars
-Have a brand new car that i'm making payments on now
-Really really really really want to make the convention!!!
-I'll be deployed in Sept, and don't have anywhere to put her.
-SEE LAST PIC;):naughty::evilgrin::):munch::woo-hoo::swing:
And now the pics!!!!
025
024
023
026
017
020
019
043
013
018
011 1
012
037 1
033 1
^^^^This ones NOT 4 sale!^^^^
Shopower400
Atlas
Electric City, NY
bump???
i can't beleive there's no interest! If it sells to some sap who runs it into the ground, i could care less at this point; it really needs to go! I would however feel a little better if she went to a good home:) It's also 4sale on AutoTrader, so...........
girard176
Québec
Still for sale? I could be interested... I just need to verify the procedure to import your car to Canada. I would fly to you location and get back to Canada with the car!
Shopower400
Atlas
Electric City, NY
Yepper's she's still for sale. I will be home on leave (Albany) from July 20- August 2, so we could probably set something up that'd be a little easier for you. My little bro just started school up in Platsburgh, so i could potentially even meet up with you that far?! Shoot me a PM, and we can set something up! This is really a nice car, and everything in the AD is just how you would get it. I'm not the kind of guy who unloads his problems onto the next...
Sal:salute:
Shopower400
Atlas
Electric City, NY
Bump?:munch:
This is as low as i can afford to go. Someone please give this lightly modded SHO a good home, and pick up where i left off!:sun::thankyou:
boat
Likes blue ones
Tallahassee, FL
I noticed your seats are 50/50 (duh, from the title), and I noticed you have all of the buttons on the passenger seat that are normally on leather passenger seats. Did you remove the leather seat bottom or skin and put on the 50/50 skin? I like that. :thumb: :)
Shopower400
Atlas
Electric City, NY
Nope. They come like that. Although, I did replace the headrest's with all leather ones. I think it gives it a more 'sporty' apperiance!;)
Kens1992mtxSHO
The Commonwealth
Bump for a great guy! Seen this car before in person. Runs great.
When did you get the red one Sal?
Shopower400
Atlas
Electric City, NY
ThankS!:) I got the red one up in PA (near lancaster) It's coming along nicely. The koni's & ehibach's are amazing! The only thing that sucks is i'm trying to replace the crank sensor. It looks like the water pump blew, and they fixed that + the timing belt, but they didn't know too replace the crank sensor!
Anywho, i hope to get it to the track once before the summer's over.
