Shopower400
Atlas
This car has 135k on it now, and runs perfect! I bought it back in July 06' with 80k. Most of the mileage has been highway as I frequently traveled from Dover DE to Albany NY, and back. (300 miles each way) I have done my very best to fix, and comb thru any, and all problems, and 'annoiances' that these cars usually develop, like burned out window motors & switches; seat switches; antenna; etc...................... I will list the good as "GOOD" and the bad as "BAD" So here goes.............
GOOD:
-Fully rebuilt tranny w/ LUK racing clutch & 9lb Fidanzza flywheel($2,500)
-HD reinforced motor mounts
- Flowmaster 40's catback exhaust($500)
-Gen 1 front sway bar w/ poly bushings & HD endlinks
-ALSB's
-New 'blinker' assembly
- New CV axles
- New inner & outter tie rods
- New control arms
-Upper 60k complete. (plugs/wires/coil pack; valve cover gaskets; plug well seals; serpintine belts; cam sensor; valve lash check/adjustment.)
- New radiator w/ hoses & thermostat
- Various minor things fixed such as window motors/switches; sunroof switch; antenna; center console; the box that sit under the radio; & probably some stuff I can't remember right now.
- All regular maint. has been done on time like oil changes, fuel filter, clean air filter out, and regulary wash & vaccum her out. (pics should speek for themselves)
BAD:
-Needs driver side strut mount (i'd recommend replacing both though)
-Needs Tires
-Could use rod bearings(not making any unusal noise yet.
-Could use lower 60K (does leak about 1/2 quart every 3000 miles from the rear main seal)
-Cruise Control inop. (This is the ONLY accessory/luxery item that dosn't work)
This is just about it. If I remember something i missed, whether it be good or bad, i'll be sure to add it. The reason(S) why i'm selling.......
-Can't afford car ins. on 3 cars
-Have a brand new car that i'm making payments on now
-Really really really really want to make the convention!!!
-I'll be deployed in Sept, and don't have anywhere to put her.
-SEE LAST PIC
:woo-hoo::swing:
And now the pics!!!!
^^^^This ones NOT 4 sale!^^^^
GOOD:
-ALSB's
- New CV axles
- New control arms
BAD:
-Needs Tires
-SEE LAST PIC
:woo-hoo::swing:And now the pics!!!!
