3.2 swap tweecer questions
Status
Not open for further replies.
1993MTXSHO
Its a Taurus...
Jersey
What have you guys changed setting wise when you did a 3.2 swap? I have a drop in k&n with a ported intake and BBB as well as a better flowing y pipe, (not high flow cats but that nasty 90 deg bend is gone) and a dynomax catback. I am also running the 3.2L injectors and was wondering what you guys changed the offsets and such to, to make up for the slightly bigger injectors.
firebat45
Edmonton
I'm using the tune from Josh, I believe its 27lb low slope and 72lb high slope. I don't think it's optimal but it's somewhere to start. Other than that I only changed the displacement to 195. I had a SHOShop Y and Dynomax, but no intake mods. I used the 3.2 injectors as well.
Phoenix
SHOHOLIC
QC , Canada
Besides the higher idle (rpm) set for the 40+ cams , I havnt touched a thing cept for the MAF curve.
Runs fine , cept I find it a little lean sometimes , but at 1/2 to WOT , its 13:1 to 11:1 ratio which is not bad.
Sho Amo
SmkTyresntDrugs
Olney, Md
im running the same but i raised the rev limit, put in the maf transfer, lowered the butterfly opening and added 1* of timing above 4800 and for my nitrous tune i pulled 4* timing.
yamahaSHO
E85 whore
Arkansas
Change the engine displacement and it'll run like stock (helps calculate for load). Tune to your desire from there.
1993MTXSHO
Its a Taurus...
Jersey
So no need to really change any of the injector slopes so it knows its got 3.2 injectors? I'll have to brush up on X2j tuning, I'v been all about the D4U1 for the past year:nut: But since I no longer own an ax I guess its time to start tuning for the X2J again.
1993MTXSHO
Its a Taurus...
Jersey
The 3.2 injectors a marginally larger... VERY small difference.
So you think screw it, or should I change the slopes ever so slightly? I want the engine to run perfect, I mine as well since I have the stupid chip laying here doing nothing.
yamahaSHO
E85 whore
Arkansas
I think I've been pretty clear. Even stock injectors for x motor needs 'tuned'. Put them in, log it, change as needed. That's all there is to it.
Sho Amo
SmkTyresntDrugs
Olney, Md
anyone have the ford eec tuning book recommended on the tweecer site?
i just bought it for 45 bucks. i prolly shoulda asked before i bought but just asking for opinions.
1993MTXSHO
Its a Taurus...
Jersey
Is it the one the tweeecer manual recommended? If so yup I have it, best book I bought in my 22+ years on this planet.
gmail
Well-Known Member
sunbury pa
27, 72 is factory 3.0 settings for injector slopes.
i dont think many guys understand the one on shonuts website is a factory x2j file nothing has been done to it.
Status
