JRA2000TL
The Complainer
Look at the image below and enlarge it to full-size.
The unit on top is a dealer warranty service replacement for/from a Lincoln Continental. Note the smaller border around the faceplate, as well as the later-style fan-speed wheel (ie. has "bumps" instead of grooves). You cannot see it in the image below, but while the display window is the same size, the "numbers" portion of the display that displays the inside/outside temperature is smaller than the OEM unit:
The bottom unit (above) is from a 1995 Sable wagon. It too is a service replacement unit, but it has the green (versus blue-green) display that was used in the 95 Taurus/Sable.
Coincidentally after reading this post and seeing the differences, I ran across one of those hard-button warranty replacement units (with the smaller number display) in a junked 93 LX wagon at the pick n' pull. I snatched it up for $10.
