Its alive... NEW PICS PAGE 2
yamahaSHO
E85 whore
Arkansas
Blow... Suck... Both feel... eh.. sound good to me.
You better dial some timing back sooner than later. I'd hate to see you crack a piston before you really get to play and learn with the newly found happiness.
firebat45
Edmonton
very clean
is that an external starter solenoid? does the starter still have one? so you have 2?
Yes, yes he does. I'm sure he'll figure out a way to scrap one of them, but he just had to get a Gen 2 starter for clearance and hasn't sorted stuff out yet. 2 Solenoids is not recommended, it might have been the cause of some problems...
1995SHO9
FLEES ARE COMIN
Carlisle PA
Looks awesome Mitch. Very clean install. You did an awesome job.
Any plans to use header rap on the piping to insulate against heat?
SHO_DOODmorrris
Owner & Fanatic
Alberta
no i wont be using exhaust wrap on the charge pipes, i'm using this adhesive backed fibergalss heat shield stuff that has tinfoil on it kinda. ill take a pic later.
thanks for the props guys, like i said its not anywhere near done and its messy as **** to me. first thing i'm changing is stainless braided oil lines and AN fittings to/from my oil filter relocation kit. i don't trust those rubber lines, they are already kinking a bit.
As for timing, i took a bit off of the spark adder vs RPM about 5 degrees up top and 2 or 3 down low but i think ill add that back in because i'm not boosting till after 3500...about. Also i need to tweek my fuel tables because before i'm in boost i'm running between 15 and 18 before i hit boost. as soon as im in boost it drops to 12 or lower. at idle its leaner than the WB can read (higher than 18) but w/e i have some reading to do. by the way is there a ring set in procedure for the wiesco rings?
-Mitch
SHO_DOODmorrris
Owner & Fanatic
Alberta
is that the turbo from a 7.3 ford?
edit*
its a very "clean" install. very good job
No, its actually out of a Dodge ram Cummins. This is the Holset HX35W. Rebuilt it as well with a rebuild kit off ebay. very nice turbo so far :) thanks :)
-Mitch
SHO_DOODmorrris
Owner & Fanatic
Alberta
How much timing should i pull when running 94 octane on about 8-10 psi? and also what should i pull that out of? WOT spark advance? also for fuel it seems to be sucking it back pretty good despite being out of boost and running 15-16:1 afr on the highway.
1995SHO9
FLEES ARE COMIN
Carlisle PA
1 degree retard per pound of boost okay. If you want to be safe you can retard it more.
15 16 on the highway is kinda lean but not to bad. 14.7 is desirable (spelling?)
Vnuk1
Mr. Mayhem
Someday mine will be boosted. But I am already ******** so I am ahead of the game. Aren't I? Great Job SHO_DOOD!!
SHO_DOODmorrris
Owner & Fanatic
Alberta
SHO_DOODmorrris
Owner & Fanatic
Alberta
Got the tuning figured out nd now boosts like at least twice as fast. also here are some recent pics.
Downpipe (dont mind the messy/****** welds on the ****** theres good welds underneath just wanted to patch a few spots up)
car
Left-Buddies Chipped modded GTI with about 240 WHP on the 1.8T (tq monster) Mid some *** with a turbo taurus... who does that anyways? Right- Other buddy with his turbo MR2 CF hood and Blue primer :p
SHO_DOODmorrris
Owner & Fanatic
Alberta
im too embarrased to post any more engine bay pics.. its so ******* messy and hackjob looking... it all functiuons properly but give me a month and i should have enough money/time to do some things properly that are really bothering me.
thanks
-M
Rubix
Aww cmon, it's gotta look better than that hackjob bumper :biggrin: Sounds like she's comin' along nicely, everything looks great in that picture third from the bottom in post #35 :thumb:
SHO_DOODmorrris
Owner & Fanatic
Alberta
List...
Replace oil feed lline to turbo with a real one not a chepa ebay one.
replace oil input/output lines to and from the oil filter relocation kit with AN fittings and ss braided lines
replace all rubber couplers/reducers with silicone.
replace all hose clamps with T bolts.
rig somthing up for a speedo.
install ACT sensor in charge piping.
Install and trim bumper skin
purchase and install bigger intercooler with 3" inlet and outlet
upgrade to a 90mm lightning maf
purchase and install a new BOV
make a new wiring harness (will do that when i do a RWD conversion this winter)
replace all rubber vacume lines with silicone.
figure out my sticky starter soloniod problem
bigger brakes...
lots more i cnat remember.
P.S blaine i like that idea.
-Mitch
shobroooo
