Compression...yeah, about that....
jthod
Mr. Goodwrench
Lincoln, Nebraska
Just got in after checking mine. Stock 3.0, 124k, regular oil changes, 60k top and bottom done at 104k (me), as well as rod bearings.
Just after getting the exhaust done, I noticed smoking at WOT. I was told black smoke, so I thought rich. Thermostat, ECT, temp switch, and black smoke was gone. Now there was blue smoke.
I parked it about a week ago, and just got to testing it tonight. I was thinking probably valve stem seals. I had a miss at start-up after sitting for a few days, and oil was caked on the back of the valves.
Test was done after it has sat for about a week, so it WAS NOT at operating temps. I can see the sompression being slightly lower, but not like this.
Compression was as follows:
Cylinder #1
dry-110psi
wet-110psi
Cylinder #2
dry-90psi
wet-140psi
Cylinder #3
dry-60psi
wet-95
Cylinder #4
dry-90psi
wet-90psi
Cylinder #5
dry-50psi
wet-70psi
Cylinder #6
dry-60psi
wet-80psi
I guess it's time for an upgrade...
hawkeye18
Sorta cares
Norfolk, VA
Well numbers are going to be low if it isn't warmed up, but 2 and 3 definitely look pretty bad. The difference in numbers is the biggest indicator... sounds like a good time to go for some Wiseco pistons! :laugh_ti:
jthod
Mr. Goodwrench
Lincoln, Nebraska
if only I could spare that kind of coin. I really don't want to spend money on this thing.
Kind of a shame, it's only got 124k!!! I baby the damn thing, and I get this shit?!?!
hawkeye18
Sorta cares
Norfolk, VA
Try letting the engine get up to operating temp (have it running a good 20-30 minutes to let the oil heat up all the way) then try it again. That really will give you a better indication of the health of your piston rings and/or valve seals.
jthod
Mr. Goodwrench
Lincoln, Nebraska
I know, I already had the intake off to check the back of the valves, and it looks like I need to do seals also.
I gues I found my summer project, too bad it's not cheap or free.
hawkeye18
Sorta cares
Norfolk, VA
Valve seals and even piston rings are pretty cheap.
But then again, so is a blend door actuator...
LJRuddy
Pop lock n drop
Poaceae fields
Joe, I feel ya broski. I think my next big purchase will be either a gun or a bicycle :nut:
Lets meet up, get drunk, and cry together. Maybe we can elope back to North Platte again! :lol:
yamahaSHO
E85 whore
Arkansas
Drive the car around, park it, pull the intake off immediately, one plug at a time (replace when moving to next) and check the compression. Be sure to crank until it stops progressing. If you get low numbers like that again, try another gauge.
itwonder
VA
Did you have throttle plate fully open when you ran the compression test?
CademiaX
What's an SHO?
Utah
you should sell it to someone we can take care of it properly and you should ride the bus :)
1993MTXSHO
Its a Taurus...
Jersey
Does your engine run smooth or even semi smooth? If it does then those numbers are wrong, and the gauge is screwed up. With numbers like that the engine would **** around and run terrible and probably not have much power at all. Get a different gauge, warm the engien up, and run the test again.;)
Get two bottles of Auto-RX. After 10k miles driving it hard it will run like new.
1995SHO9
FLEES ARE COMIN
Carlisle PA
Why are people saying to pull the intake to do a compression test?
I was told to drive it around for awhile, pull all the sparkplugs, unplug the dis, and then crank it over for 4 seconds and see where it hits.
Oh an don't worry about the rings dude, my 91 has blowby like crazy and still has the quickness. I burn about a quart every gas fill up. Drive the thing until it blows.
Oh, and I assume if those numbers were correct, it would run like total shit...
~Johnathon~
yamahaSHO
E85 whore
Arkansas
Two reasons. First off, it provides far less restriction to the cylinders to induce a more accurate reading during a compression test. Second, you don't have to work your way around a huge intake.
1995SHO9
FLEES ARE COMIN
Carlisle PA
"You can't change sparkplugs on a SHO without pulling the intake off".
:rofl:;)
AREA 91
Area 91
This is true, but almost no one does it.
:rofl:;)
I wouldn't tale too much smack there little John. It takes you 2 hours to change pads and rotors.:laugh_ti:
Um... Okay...
Punch him in the face.
Joking.;)
hawkeye18
Sorta cares
Norfolk, VA
Next person who makes a spark plug joke gets his sunscreen put up on a tent pole.
Oh wait... :theyareontome:
jthod
Mr. Goodwrench
Lincoln, Nebraska
Thing is, I've taken great care of it. Bastard car.
No, it runs great, other than the smoke. I used the guage at work the other day on a cold 7.4L engine and read 160psi.
I need to put it together and warm it up.
10k miles? Thats like 6 months of waiting. I've been thinking of running some of that through, that should take care of all the carbon. The top of the pistons are pretty caked.
X2, give the engine all the air it can take.
I'm going to through it back together and run it for a while and check again. I already found a 3.2 for $200, or a parts ATX for $400. :naughty:
shobroooo
