ease on faster than wot?
bigblock
cali
this is my 93 3.2 mtx. my 0-60 at wot is around 9 secs. it bogs down low and doesn't like 7k rpm much anymore. BUT! if i ease on the throttle and feather it towards the upper rpms it pulls allot faster and rolls right up to 7k. its like it has a sweet spot or something.
i had 2 extra old tps's. one made it worse the other was better over all. helped but didn't fix it.
i though i had clogged cats. so i gutted them <_< >_>. the rear bank was melted. i got some power back but its still SLOW. my cps is old and my crankps is old. i reused them in the swap. same with the rest of the censers. my plug wires were reused.
thats all the info i can really give. oh! one of my cam chain tensioners is bad but i dont think thats related. anyway i dont know what else to say. other than its slower than my 90. i can take a video if you guys think that will help.
thanks for all the help in advance.
SHO GoDz 89
True Sleeper
Monroe Twp, NJ
Timing? That's a weird problem. I guess try and get a good TPS on there, maybe swap in a better PCM.
Crank sensors don't give you performance issues when they go bad, they just don't let your car run at all.
This might be a weird question, but would there be a way for the throttle plate to open more than WOT? As in go past WOT, thus closing the opening a bit and maybe the TPS registers it as closing. Not sure if that makes sense but that could be a problem.
Anyways, try a good TPS. If that doesn't work, then start replacing any other likely culprits (starting with the cheapest stuff).
bigblock
cali
i checked the throttle its good. opens all the way and not any further.
i'll take the tps off my 90 and see if that helps.
shomtx95 said:
try new plug wires, maybe when you suddenly stomp it, its having a hard time burning the fuel.
i have an extra set so i think i'll try that first. i also have spare coil packs so i'll try that too.
