passenger drive shaft.
tdaily2
South Carolina
does the long 1/2 shaft lock into the trans like the driver side? i can not get mine to lock in. or does is it get held in by the center support .:munch:
itwonder
VA
The passenger side does not lock in like the drivers side does. Thank goodness.
AREA 91
Area 91
The passenger side innermediate shaft on the MTX is NOT held in by a C clip.
sdpatt
Sr. SHO Engr.
Dallas, TX
The large coupling slips over the splined intermediate shaft on the passenger side of the intermediate shaft bearing. If you got the old shaft out, it should be quite obvious where the new shaft installs. I thought there was a C clip on the intermediate shaft's splined section that inserts into the CV halfshaft's female coupling.
AREA 91
Area 91
You are correct Pat. The only C clip on the passenger side clops into the innermediate shaft.
