axle
tdaily2
South Carolina
im having problems getting the p-side axle to lock in do they lock in or are held by the by the bolt from the bearing? help asap.
On the end of the axle that goes inside the trans, there is a "C" clip that snaps into a groove inside the mating piece in the trans. That clip is listed as a "one time use" piece, although I have re-used them successfully. If that clip is missing or bad, the axle will not be secured in the trans. Reportedly, the axle cv joints will not long survive this condition, so it is not something to be ignored.
AREA 91
Area 91
The passenger side on an MTX is a 2 piece design. There is an innermediate shaft that has the carrier bearing on it. This carrier bearing bolts to the rear engine/power steering bracket with 2 10mm bolts. The passenger side CV shaft connects to this innermediate shaft via a C clip. These C clips can be very difficult to remove sometimes. A few sharp tugs with a pry bar should release it from it's home.
Hope this helps, Brian
tdaily2
South Carolina
yea i have them out and put the d side in and can not get the p side to go in. so does anyone know the part number to the clip?
