oil leaking
big smoov
md
oil is leaking on the cat and causing it to smoke.and loosing alot of oil any suggestoins where it comming from .i had the valve cover gasket replace to weeks ago. 94 atx
shospeed
austin tx
Clean it all up and put the car in jacks turn it on and watch it leak.
But if I hade to guess it would be front main seal or oil pan.
Kens1992mtxSHO
The Commonwealth
Possibly a pinched valve cover? Was it leaking before the valve cover replacement?
big smoov
md
oil leak
yes it was leaking before the valve cover was replace. their is oil allover the cat on the pasenger side. about how much would it cost to do the cam seals/front main at a shop
big smoov
md
oil leak
benjammin
washington st.
That was happening to me when my front main seal was leaking, but I was never able to discover where it was coming from until I ran some engine dye through it. Then it showed up plain as day.
benjammin
washington st.
For 6 bucks and a couple bloody knuckles you can do the front main seal...might as well do the timing belt while your there though.
