Gen III SF swap; bushings ?
shobote
Naperville, IL
For those who have doen the Gen III SF conversion, do you use all 4 stock
'96 SF bushings ? that is, the 4 rear '96 ones from SHonut that are used as an upgrade for Gen I and II would not work with this setup ?
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
You can use those or aluminum bushings. The last one I did, I just used the stock gen 3 bushings IE: fronts were they go, rears where they go.
shobote
Naperville, IL
Ever done the ALsfb's in the front and Gen III's in the rear ? I talked with one guy who did this on his '89 and he said great steering response without all the harshness.
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
SinisterSHO's car had aluminum/gen 3 rears. It was fine. I really dont think it matters which way you go. The Gen 3 mounts are just fine.
