Cut Eibachs and Sensatracs
jthod
Mr. Goodwrench
Lincoln, Nebraska
Yep, quite a few guys go with that setup, including myself. I have about 500 miles on mine, and I'm loving it so far.
whiteman_01
Well-Known Member
Hastings, MN
You should be good for the first summer. Thats when mine started to pogo a bit. Wasnt horrible, but it did. I cut one coil btw.
hawkeye18
Sorta cares
Norfolk, VA
Sensatracs were not meant to be used with lowering springs; the valving is not strong enough and will deteriorate after a short period. They will work fine for a while (anywhere from 500 miles to 20,000 miles based on driving conditions and styles) but will pogo eventually.
If you're comfortable with that, then by all means go right on ahead.
SHOmethewayhome
BAD ROLE MODEL
Saint Paul, Minnesota
any suggestion for a currently available strut that can handle cut eibachs? i'm considering it myself since i haven't installed them. i have a set of eibachs and a set of sensatracs, gonna be a little tee'd off if i gotta replace them after 500 miles.
whiteman_01
Well-Known Member
Hastings, MN
Did you already cut the springs? If you haven't, just install them uncut. I don't think you'll be disappointed. Except for maybe the ride height.
89SHOMAN666
SHO NUT!
Reading, PA
That's what I have on several of my cars. Two have eibach and sensatracs, the others have intrax and sensatracs. But I didn't cut coil as that seems to aid in not having the pogo stick affect.
Really crappy cellphone pics:
Th 88359 IMG 0501 122 350lo
Th 88360 IMG 0499 122 560lo
SHOGUN88
1994 MTX
Langley, BC Canada
No I havent yet, I dont know maybe ill just save up for some konis I would like a lower ride height, especially in the front.
whiteman_01
Well-Known Member
Hastings, MN
Un-cut they seem to be a good combo. I didn't have any pogo until i decided to cut the springs. Nice firm ride, and handled pretty well too.
Sho Amo
SmkTyresntDrugs
Olney, Md
i have sensatracs and im running a 3.5in drop. they are sho shop linears and i beleive i have about 10k on them.
kikkinasphalt
Wrrrrrrrr
Missouri
you hush up with your logic! :laugh_ti:
OP:
would i do it? no prolly not.. but it is your car..
