SHOGUN88
1994 MTX
I have a set of Eibachs waiting to be installed, will sensatracs still be ok if I cut one coil off the front?
thanks
thanks
Did you already cut the springs? If you haven't, just install them uncut. I don't think you'll be disappointed. Except for maybe the ride height.
Sensatracs were not meant to be used with lowering springs; the valving is not strong enough and will deteriorate after a short period. They will work fine for a while (anywhere from 500 miles to 20,000 miles based on driving conditions and styles) but will pogo eventually.
If you're comfortable with that, then by all means go right on ahead.
