HotRodKid
mmmmm ... turbo
starting to rewrite a list i had for a turbo ls1 project so that it applies more to the SHO, but this is a pretty good start so you can see what kind of stuff you need on your project.the idea being its always the little stuff that runs a project into the red. ill add more to the list as i think of it
tubing: figure out your needed sizes and how many bends it will take
y pipe should be 2" before and 2.5" after the y
waste gate recirc is 1.5 or 2"
intercooler pipe is usualy 2.5
exhaust after the turbo is 2.5 or 3"
exhaust & turbo
Intake:
couplers:
Fuel / tuning
FPR parts list:
engine & tranny parts:
vacuum system:
coolant system: for water cooler turbos
gauges:
Steel stock
Bolts:
Random Supplies & Gaskets:
example: said:304 stainless:
(1) 2" 180 degree
(3) 2.5" 180 degree
(3) 3" 180 degree
mild steel:
(2) 2" 180 degree
(2) 3.5" 180 degree
exhaust & turbo
- manifold flex pipes
- NBO2 bungs
- WB02 bung
- Turbo
- turbo flanges
- hotpipe transition - fits a round pipe to the square ****** of the turbine side inlet
- oil lines and fittings (as follows)
T block to screw into the block (one outlet for the stock sensor, one for the turbo supply)
hose .... plenty of frickin oil hose
barb fittings
oil pan fitting (bulkhead style or screw in) - Wastegate
- Wastegate ******'s
- wastegate gaskets
- wastegate flexpipe (not applicable for open dump)
- turbo heat shield (stainless steel cooking pots work good)
- heat wrap & clamps for it - at least 2 clamps / section wrapped
- ****** to mate your downpipe to whatever exhaust is on the car
Intake:
- filter
- does your filter require a reduce to fit onto your intake pipe? (ie:4" filter on a 2.5 pipe)
- BOV - recirculated ? add tubing to the above section if so
- Intercooler
- tbolts or hose clamps
- Boost Controller - optional
- IAT sensor bung
couplers:
- filter pipe to turbo
- turbo to charge pipe
- charge pipe to intercooler
- intercooler to charge pipe
- charge pipe to maf - reducer style
- maf to charge pipe - reducer style
- charge pipe to throttle body
- couplers for anyplace you decide to split your pipes for ease of install / removal
Fuel / tuning
- fuel pump
- in tank filter "sock" for the bottom of the pump
- external filter - youll be pushing way more fuel, you need a new filter to make sure you get it all
- injectors
- injector o rings / spacers if required
- tuning software
- fuel pressure regulator (if not a kit, see list below )
FPR parts list:
- FPR
- banjo fitting & bolt for fuel rail
- in & out fittings on FPR
- plugs for unused FPR ports
- stock fuel return line spring lock coupler + adapters it may require
- fuel pressure gauge
- high pressure fuel line - can be bought after you mount everything else, allowing you to measure your exact needs
- electric oil pump - scavenge pump for low mounted turbos
- engine oil cooler - optional
- tranny oil cooler (atx cars)
- oil pump lines -
- oil pump wiring / switch / relay
- oil catch can & fittings - optional
- serpentine belt - if deleating a/c
- upgraded engine mounts - optional but very good idea to combat wheel hop
vacuum system:
- distribution block
- vac line the proper size for the following parts:
BOV
FPR
waste gate
brake booster port
boost controller
crank case vent
catch can (if you install one)
- coolant hose - TB bypass size
- Brake lines - 2 pcs, long enough to go from TB to turbo
- banjo or barb fitting that fit turbo in and out
- coolant hose to connect said fittings to said brake lines
- hose clamps for each connection
gauges:
- wideband
- boost
- oil pressure
- tranny temp
- engine oil temp
- fuel - mech on fpr
- gauge pod
- wiring (pos, neg, + multiple colors for signal wires)
Steel stock
- turbo mount - angle iron
- intercooler mount
- intercooler shroud - if your so inclinded to make one
- piping brackets
Bolts:
- manifold -> y pipe
- Y pipe -> turbo
- turbo -> dump tube
- wastegate
- turbo support bolts
- piping mounts
- intercooler mounts
- Coolant
- oil & filter
- RVT gasket maker
- loctite
- Copper antiseize - COAT EVERY SINGLE BOLT !!!
