Ford's loctite cam repair
Has anyone actually done the Ford 'approved' cam rework with the Loctite? Are there any known failures of cams that have had that rework?
SHO U UP
SHO Guru
Virginia Beach, VA
Really iffy. There was some info on the other forum about that, but why go thru all the trouble doing that when you can weld them while you are there. That way was basically "band aid-ing" the problem, while the weld is "surgically" fixing the problem. Just weld it.
AREA 91
Area 91
I would only use Loc Tite, Mighty Puddy, or JB Weld if someone had a gun to my head.
Do it correctly, weld it.
nothingtoseehere
Brian, watch the commercial, mighty putty can be used for automotive repairs. And it has the strength to pull a fully loaded 80,000lb trailer.
If you call now, you can get 6 sticks for 19.99 if you "order now"
hawkeye18
Sorta cares
Norfolk, VA
If you call within 30 seconds, they'll send you a copy of "2girls1cup" on DVD - it's about as useful as mighty putty!
Seriously, Pop. Mech did an expose on the "as seen on TV" stuff and their verdict on it was "useful for making coffee cup handles. Anything else, not so much...". And then they said "Just buy another damn mug, you cheap bastard."
1995SHO9
FLEES ARE COMIN
Carlisle PA
Yah, I think he actually went though with it and used the Mighty Putty. I hear they are still holding up....
Me and another V8 SHO busybody used the Loctite before the Ford TSB. Where do you think they got the idea.....
OK, I already knew all the editorial stuff......
The question was, have any with the Loctite failed?
hawkeye18
Sorta cares
Norfolk, VA
Using loc-tite to fix the cam gears on their shafts is almost the dictionary definition of "Mickey Mouse" engineering. I'm sure it'll work... for a little while.
Well it is special Loctite for bonding shafts to gears and not the usual thread locking crap.....
313tiger
