Your thoughts on transmission
Bs704
Mesa arizona
Good morning
Just picked up my 14 sho. I took it to a buddies shop to change out all fluids and few other things. They do not want to touch the transmission because they are not built for that. They said there is a leak unknown location I have not seen it personally. I am having no issues in shifting or anything along those lines. Not doing stupid stuff with the car just back and forth to work. Should I just keep an eye on it and wait till something happens? No major leaks in the ground.
kryptto
South East, Florida
I had to have mine recalled.
kryptto
South East, Florida
TSB 16-0043
6F35 TRANSMISSION - FLUID LEAK AT LEFT SIDE HALFSHAFT SEAL - BUILT ON OR BEFORE 10/14/2013
kryptto
South East, Florida
TSB 16-0043
Could be that - just a start - keep an eye for the pink oil making marks - learn where the filler is next to the battery under the airbox.
Check the fluid level. The dipstick is under the air box.
Tbird6
Yes. I found this is awkward because to check the fluid level you need to start the car. With the air box removed you will set a code. No big deal but I try to reposition the air box leaving the wires connected when I check fluid.
Don't want to complain too loudly because my MKS is one of the very few modern cars that even have a dipstick!
poffffd
