Your best ETs
MetalheadSHO
Wichita, Kansas
I don't know if this topic has been posted already, but I thought it would be fun.
Tell me what you best time (or times) is/are, and what mods you have/had done at the time of the run.
My first run at the track was about a month and a half or so ago, with a fresh tune up (new Autolites, Motorcraft wires, timing belt, new air filter [not a K&N]) and some shotty Douglas All-Season radials. The first time I ran a 15.3 @ 84MPH because I got a crappy launch. The second run, which was my last of the day, the track was packed, was a 14.8 @ 89MPH.
At least I got to see what she was capable of at the track before I let her go...:biggrin:
SHOspazz92
Banned
Triad Area, North Carolina.
Your trap speed seems extremly low for a 14.8 Run.
My best run was a 15.01@93 MPH, With a 2.3 60' On Used front tires, Busted Motor mounts, Bad 02 Sensor's, The car overheating and at a Elevation 3,000 Feet.
-Sam
MetalheadSHO
Wichita, Kansas
-Sam
I just took a guess at the trap speed. My time slips have since gone through the wash and dry. :nut:
SHOspazz92
Banned
Do you remember 60'? Your 1/8th?
You should have just posted that in the first place....
-Sam
Cocoa,Florida
my guess is that if you were able to get a 14.8 out of your car
you were in the 93-95MPHrange. 89 is way too low.
SuperHO
Mental Patient
St. Joe, MI
The best 1/4 time I've gotten was a 15.49@96mph with a 2.6 60ft time. I've run a best of 9.4@74(?)mph in the 1/8th with my 92 with the same engine that's in my 95....I think it goes without saying that traction was an issue that night on the 1/4. I have the following:
possible 3.2 swap (not sure)
73mm MAF
TB coolant bypass
Hand ported runners
reinforced front and rear mounts
custom 2.5" catback into a single flowmaster
Underdrive waterpump and power steering pulleys
I'm sure I'm forgetting something, but it's 5am, and I ain't slept in a while.
Off Road SHO
Moderator
I've done a personal best in The Other Woman of 12.48 @ 110 mph. Stock motor with a Roots style blower on it and an extremely lightened chassis. Also turned the engine 90 degrees and while I was at it, moved it to the back of the car. Changed out the AXOD to a Mendeola transaxle to help it last longer.
:evilgrin:
Tom
TwofastSHO
Andover MN
At the drags
I was out twice in Sept. my best was 14.44 @96.76 Mph. 60 ft time was 2.21 stock 3.0 lightened car with Y-pipe (no cats) single 3" exh to 1 race muffler and an Pro M 80 maf and Nitto extreme drag radials. still spinning for about 25 ft. Mark
Brook24v
Nebraska
92 SHO ~ Poor mans ram-air, weight reduction, 130k - 14.7 @98mph
93 SHO ATX ~ K&N, Dynomax exhaust, 110k - 15.0@93mph
93 SHO ATX ~ K&N, fresh tune-up, 125k - 15.3@92mph
89 SHO ~ Had lots of bolt-ons, but lack of traction kept me in the 15s. :frown:
93 SHO ATX ~ Blown head gaskets, and "G-TEC'd" 15.8@90mph.... haha :rofl:
SuperHO
Mental Patient
St. Joe, MI
Sho Amo said:
how do you not know if you have a 3.2?
because the guy who sold me the 92 (the car the engine came out of) told me he performed a 3.2 swap.....but then further investigation shows a KOA tag on the oil pump housing, and my chip burned for the 3.2 swap made the car run weird.....but I've also been told that during a 3.0 - 3.2 swap, EVERYTHING but the block and pistons comes from the 3.0, including the oil pump. I'll find out for certain when I tear it down to do head gaskets and valve stem seals.
MetalheadSHO
Wichita, Kansas
Just for laughs, I think I'm going to take the '99 SE out to the track sometime. :laugh_ti:
Anyone have any idea what it might run? No mods with the 3.0L Vulcan. It does have good torque.
MetalheadSHO
Wichita, Kansas
No. Its the 140hp with 210 ft. lbs.
I believe you're thinking of the Duratec V6. I can only WISH it had that motor. Haha.
