Yamaha V6 line drawings?
Chase42
Rocklin, CA
Hi there!
I'm looking for any line drawings or professional blueprints of the first-gen motor. I couldn't find anything by searching google or your forum, but does anyone have anything that could help me? Mainly, I'm looking for measurements as much as the drawings.
thanks guys!
93rev2sev
Hockeytown
I was looking for the same thing a while back so I could build a 3d model of the engine. I was not able to find much and nothing that I DID find had any measurements.
I started to build a 3d model of a head, but lost the gumption.
Chase42
Rocklin, CA
does anybody have overall dimensions and weight? maybe a good line drawing would be in the service manual?
AREA 91
PA SHO SHOP
Area 91
Rough dimentions used to be on here, before the forum crashed.
Dressed weight of the V6 is 485 lbs.
FWIW an all cast iron small block chevy is 550 lbs.
gmail
Well-Known Member
sunbury pa
the 485 lbs block included all wiring accessories and everything... i checked it out a few weeks back.. it even included the brackets a/c pump, belts, coolant and oil..
also this block is no slouch its very thick
firebat45
Edmonton
Overall dimensions are tricky, it depends what you include as "engine". I did some measurements last night for a project, and I will be working on a CAD drawing (not photo-perfect, but dimensionally close enough for planning)
All measurements are give or take 1 inch right now. No accessories on engine, but intake and exhaust included, as is crank pulley (MTX). No flywheel. Not sure on weight, but a friend and I lifted it into the back of his truck without much trouble. I'd guess around 350, but I could be off a lot.
Width - 26 inches (Left manifold to right manifold)
Width - 23 inches (no manifolds, if you're doing exhaust from scratch)
Height - 29 inches (with intake)
Length - Crank pulley to rear of crank - 22 inches
- Crank pulley to end of valve covers (furthest point on engine that is not relocatable) - 24 inches
- Crank pulley to coil (if relocating coil pack, all this space can be saved) 30 inches
- Crank pulley to throttle body inlet - 32 inches
I also have some photos of the engine on a stand, with a ruler for rough dimensions. Perspective messes it up a bit, so you can't use the ruler for exact measurements. I can post if interested.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
a bare block is about 109 lbs.
93rev2sev
Hockeytown
I've done a bunch of "playing" with Google Sketchup and burned myself up trying to draw the intake. I'd love to see what you've got so far.
93rev2sev
Hockeytown
hey...I just realized, I have the 95 Ford Vehicle Service Manual on CD and there are wiring diagrams for the Mark. Are you sure the radio is dead or are you unsure you've got it pinned out correctly?
poffffd
