pete c
When I took my y-pipe off a few weeks ago to do my rod bearings, I snapped one of the manifold/y-pipe studs off. I drilled it out, but was a little off center. So when I retapped the hole, it was a little sloppy. So when I put the nut on it and started tightening it, rather than stopping when the threads were bottomed, the stud kept screwing into the manifold hole instead of the nut spinning on the stud. So, rather than cranking it down to spec, I left it kinda loose.
Now I have a bit of an exhaust leak. I guess the proper way to fix this would be to remove the pipe again, drill out the manifold hole and install a helicoil. But, I'm a lazy sumbitch and don't wanna do that. Would smearing a little jb weld on the stud threads work? I guess I could also put a nut on the back of the stud where it pokes through the manifold ******.
